Drilling TB blade for startup and idle
Cracking the tps blade too much can cause issues too.
Heres what i do. Set the blade set screw to where the TPS voltage is within factory spec at 0% throttle(search that voltage i cant remember it off the top of my head). From there, drill the throttle blade until you get an IAC count of 40-80 when the motor is up to temp in park/neutral. This method keeps the PCM happy and the motor happy.
I made some adjustments last night and its much better. Turned the set screw in a bit and now i get start up no problem. Just need to adjust the IAC as when im idling it moves the truck, should be a simple adjustment. Just a little fine tuning and it should be good to go. TPS seems to read good as well.
I meant the top of its range during slow cruise or idle, not high RPM. Mine counts from 0-about 100 and 80-100 isn't much room for making adjustments when it trying to compensate for the throttle blade slamming shut.
Damn I have the same problems as you right now that justin and I have been going back and forth on. I have a 102MM and every day on start try to adjust Blade to find a sweet spot.
Just sent justin this video the other day as I get this **** too.
https://www.youtube.com/watch?v=pJJs3GbEQ4w
