Draining ATF...
Old Jan 14, 2004 | 12:57 AM
Hit Man X's Avatar
Default Draining ATF...
Okay, I am gonna drain my stuff. Will I need about 6-8 qts w/ a pan drain only? And YES I know the 4x4 pan hold a wee bit more...
Thanks!
Old Jan 14, 2004 | 12:58 AM
Flyer's Avatar
Sounds good to me ... I think mine held 6 when I did the shift kit. That was all the fluid from the VB and SP too.
Old Jan 14, 2004 | 10:03 AM
BigKID's Avatar
The book says five with a filter change. I put 5.5 in mine after the shiftkit. I will be changing it all again today while installing the converter and the book calls for 11.2 qts.
Old Jan 14, 2004 | 04:04 PM
13 Second Truck Club
From: Pueblo de Nuestra Señora la Reina de los Ángeles de la Porciúncula
When I had the stall, shift kit and cooler done, 5.5 qts. were put in if I remember correctly.
Old Jan 14, 2004 | 06:29 PM
BigKID's Avatar
You better check you fluid level then! I just put 6qts in after changing my converter this afternoon. Add that to the 5.5 after installing the shift kit.. thats 11.5qts.
Old Jan 14, 2004 | 06:33 PM
Flyer's Avatar
I added 2 quarts when the stall went in ... I added another 3 or 4 quarts as soon as I got to Wal-Mart. The pan was never dropped.
When the pan and valve body and all were droppped I put in another 5-6 quarts.
Chingon .. that might have had something to do with your tranny problem if your fluid is low. Be sure you check it warmed up and running.
lxcoupe
Sep 25, 2015 12:36 PM
726.0chevelle
Sep 12, 2015 09:24 AM
CategoryX
Aug 30, 2015 01:34 PM
hartinclay
Aug 3, 2015 07:03 PM
