doin the 6.0 this weekend
Old Aug 18, 2006 | 07:30 PM
  #21
litreddevil's Avatar
Banned
i have done this 2 many times this is about a 4 to 5 hour job real easy to do.just move the hood hing up where the hood is straight up and down,remove fan elec. or clutch,i remove the 2 hoses off the p/s pump and the hole bracket with alt.,then take of the intake complete just undo the injector harness and fuel rails put wiring under the windsheild wipers to hold out of the way,then tie your steering wheel so it can not move,then undo the bolt that holds the steering shaft then you can get to the 3 15 mm bolt that hold the motor mounts.you will need to undo the ex.also if you have stock manifolds they can stay on just undo the y pipe.then undo the trans and convert bolts and it is ready to come out.
any other ? just give me a pm i'll give you my number and talk you through it
Old Aug 19, 2006 | 12:26 AM
  #22
well im at the point ready to disconnect and pull the motor, everything is disconnected. do i need to remove the shaft ??
Old Aug 19, 2006 | 12:51 AM
  #23
thunder550's Avatar
High on diesel fumes
I didn't remove mine.
Old Aug 19, 2006 | 10:11 AM
  #24
Kano's Avatar
Originally Posted by Colby 04
Here's my advice for the swap...
take notes - make note on paper of the sensors you unplug, the grounds you disconnect and the location of different hoses that connect here and there. Sound stupid? no. I reviewed my list after I thought I had done everything and it turns out I forgot to plug the coolant temp sensor back in - it was hidden by some stuff. If not for the list, I would have lost track of the grounds as well - there's more than a couple. Take good notes and you won't have a problem
Good luck
This is good advice
I labled all mine with masking tape and a sharpie in addition to writing it down on paper
ex 1a-1b, 2a-2b ,3a-3b etc
took a little more time but it went back together quick
+ ease of mind knowing everything is correct when marked off the list
is nice
bearden86
26
Nov 15, 2015 03:58 PM
cheyenne383
Nov 13, 2015 09:24 AM
GMCtrk
18
Oct 6, 2015 03:48 PM
turbo6c3
Oct 5, 2015 06:11 PM
twake_410
Sep 25, 2015 10:09 PM
