doin the 6.0 this weekend
Old Aug 17, 2006 | 01:28 PM
so what you are saying is i dont need a complete 6.0 with all accessories and harnesses. i just need a long block which consists of block, rotating assembly, heads?
Old Aug 17, 2006 | 02:22 PM
treyZ28's Avatar
basically. seriously, think of it as taking the engine out and putting it right back in. Nothing changes other than a casting number
Old Aug 17, 2006 | 03:06 PM
i need to change my flex plate? from 02 6.0 from a 2500hd?
Old Aug 17, 2006 | 03:36 PM
thunder550's Avatar
High on diesel fumes
Yep the 2500hd motor will have been mated to a 4L80E, which is a different flexplate from the 4L60E. Should be able to do a direct swap from one to the other.
Old Aug 17, 2006 | 10:48 PM
so just change flex plates, unbolt and rebolt?
Old Aug 18, 2006 | 12:22 AM
goshawk23's Avatar
Truck addict
i'm doing the same swap this weekend. good luck to ya. i'm sure mine will end up with problems.
Old Aug 18, 2006 | 08:11 AM
Flexplates? Just Unbolt My Stock 4.8 And Replace The 6.0's With It????
Old Aug 18, 2006 | 08:14 AM
yea, because the flexplate that comes with the new motor is meant for the 80e so it will not connect with the 60 but your olf 4.8 flexplate was meant for the 60 so you should put that plate on your 6.0
Old Aug 18, 2006 | 09:03 AM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
If you have a few brain cells you will be fine, I didnt take any notes and pulled the motor 3 months later I put my 418 in and all was well as far as install goes. Just remember the plugs on the oil pan and make sure wherever there is a sensor there is a plug in it. Be VERY careful with the oil pressure sending unit.
Old Aug 18, 2006 | 06:51 PM
budhayes3's Avatar
PT's Slowest Truck
To confirm what Soon2bSpooled said, yes, re-use the flexplate from your 4.8. (just wanted to make sure that was clear to ya )
Hey it's Friday...have you started yet????
