does disabling AFM prevent the lifters from failing?
Old Oct 20, 2013 | 10:50 AM
1redta's Avatar
Default does disabling AFM prevent the lifters from failing?
Like the title ask. I just got my 08sierra with the LY5 back from the dealer for warranty work. The engine had 65,000 miles and one month left of the 5year 100,000 power train. The tech found the number 4 lifter to have failed and replaced all the lifters, lifter guides and cam plus associated hardware and fluids. My question is will tuning the AFM out keep the new lifters from failing again. I would like to swap the lifters to LS7 with a cam swap but that isn't it the cards right now.
Thanks Art
Old Oct 20, 2013 | 06:39 PM
Blackpanther99's Avatar
Far as I know no. They are pretty much requiered when it comes to deleting the AFM and DOD. Most common lifters for that process are some LS7 Delco lifters.
Not the first time a GM motor has these AFM issues with lifters going out. Pretty big issue years back that GM had to deal with. Sorry if I misunderstood your question.
Old Oct 23, 2013 | 07:30 PM
1redta's Avatar
Ok we'll how many people have had there AFM repaired and had it fail again?
Old Oct 23, 2013 | 07:46 PM
craigsix's Avatar
ive got 11000 hard miles on my 2012 5.3 with dod lifters and 1.8 yella terra rockers. i change my oil every 2500 miles and i add stp oil treatment. im getting ready to install a comp dod/vvt cam 689-421-13. with stock lifters. we will see how long they live.
Old Oct 23, 2013 | 09:45 PM
2doorfury's Avatar
Would a 2011 5.3 have these lifters? Not sure if all the new v8's have DOD.
Old Oct 23, 2013 | 10:00 PM
Bit's Avatar
Bit
Yes it will have them.
Old Oct 23, 2013 | 10:59 PM
AKlowriderZ71's Avatar
11 Second Hall Moniter
You should be able to have the DOD disabled in the tune. I think it's a good idea to disable it. Keep the lifters pumped up at all times. The ones I've seen fail had varnish causing the lifter to stick collapsed.
Old Oct 24, 2013 | 11:57 AM
Vortec350ss's Avatar
you can disable DOD in the tune, but I'm not sure that will totally fix the problem. The lifters are weaker simply because they are designed to be able to collapse to go into v-4 mode.
JordanH
Nov 6, 2015 07:42 PM
Tydriver
45
Oct 23, 2015 09:19 PM
gmcyukon
Oct 5, 2015 06:20 AM
chvy=power
Sep 8, 2015 11:06 AM
Cowboy Tom
Sep 5, 2015 04:29 PM
