Do any of you guy's have....
Old Dec 31, 2005 | 05:10 PM
1badgmc's Avatar
Default Do any of you guy's have....
Any sound clips of a Comp 216/220 on a 114? I have ran a search and have found lots of Info but no sound clips. I'm thinking about this one for my 4.8 and use a TB stall behind it with a good tune. Good combo??? Thanks in advance... P.J.
Old Dec 31, 2005 | 09:23 PM
1badgmc's Avatar
T.t.t.
Old Dec 31, 2005 | 10:29 PM
mattrem's Avatar
I can tell you it will lope, it loped in my 6.0
Old Jan 1, 2006 | 09:52 AM
BLACKND's Avatar
Ok, I had this one in my 04 GMC Crew Cab. It was a 5.3 and was about a medium sized cam for the motor. It did lope but you really could't tell it much through the mufflers. Now when I had my cutouts open, you could definitely tell it was in there. Great little cam, could really feel it come in at about 1800-2000 rpm. I was running it with a Hughes Performance 2500 rpm stall converter, which IMO was too little. Ideally a 2800 converter or higher would have maximized the performance gains of the cam. Although it will run fine with a TB Stall. I have no clips, but it was a good cam. I think that Flyer was running this same cam at one time, might want to check with him on a sound clip.
Old Jan 1, 2006 | 10:15 AM
1badgmc's Avatar
thanks guys
Old Jan 1, 2006 | 12:28 PM
TXsilverado's Avatar
this is one of the cams im considering because of the numbers l33z71's old crewcab put down on the track. either this one or the tr220
Old Jan 1, 2006 | 01:41 PM
litreddevil's Avatar
Banned
That Is The Cam I Have And Always Had In All My Motor And I Just Install One In Another Motor.no Sound Clips But With A 4,8 Not To Push U Away But I Think U Will Need A Little Bigger Verter,and Shift In The Mid To High 6k Rpms Range
Old Jan 1, 2006 | 08:27 PM
Flyer's Avatar
I got some old sound clips of it in my 5.3. The blower killed the lope in it though.
http://www.woracing.com/truck/Sound%.../53%20216-220/
Right click, save target as when you download the sounds.
I put this cam in my buddys truck and it loped a little better. He's got a 4.8, it woke it up a good bit. He insists on running the cheapest gas money can buy. I was thoroughly impressed with the difference the cam made!
BKnBLK05
Dec 28, 2015 08:52 PM
Go5.3tt06
Sep 12, 2015 09:29 AM
fillpot
Jul 26, 2015 07:21 PM
lxcoupe
Jul 21, 2015 02:12 AM
GM-only
Jul 19, 2015 10:48 PM
