Differences in exhaust between 1999-2002 and 2003-2007 silverado
Old Apr 25, 2012 | 09:10 PM
E$O3200's Avatar
Default Differences in exhaust between 1999-2002 and 2003-2007 silverado
So I found a Magnaflow catback exhaust pn#15778 priced relatively cheap. The problem is I have a 2001 silverado ECSB and on the listing and everywhere else the catback is listed specifically for 2003-2007 silverado ECSB. Would the catback fit my truck perfect, will it need modification, or is it just not going to work.
Thanks in advance.
Old Apr 25, 2012 | 09:17 PM
2000chevysilverado's Avatar
Should be exactly the same you would think
Old Apr 25, 2012 | 09:30 PM
onebad03's Avatar
i think that where it bolts to the y pipe is different. How much did you find it for if you dont mind me asking. i was looking into the same catback but other things came up more important and i just ordered a muffler. The cheapest i found was $445 shipped.
Old Apr 25, 2012 | 09:58 PM
E$O3200's Avatar
i would be getting it from a friend of a friend. He wants $300 for it. I believe it has 20k miles on it.
Old Apr 25, 2012 | 10:10 PM
onebad03's Avatar
I would get it and if all else fails you could sell it or take it to a muffler shop or if you or a friend can weld then weld your factory flnge in place of the one on the magnaflow if it is in fact different.
Old Apr 25, 2012 | 11:09 PM
AKlowriderZ71's Avatar
11 Second Hall Moniter
Thanks in advance.
Your 2001 ECSB has a crossmember that the 15778 will not go around.
The factory exhaust had a bend in it that goes over the top to get around the crossmember. Some cat-backs go over it, and others go under it. Mine goes under it. I'll see if I can find a pic.
Old Apr 25, 2012 | 11:14 PM
The kit you asked about will run straight into this crossmember. I've already tried.
Old May 1, 2012 | 02:56 PM
05z71's Avatar
I need this kit minus the muffler, I have a corsa I want to install. Anybody know where I need to look or have a part number? I'm not having much luck
Slammed96
Jul 27, 2015 07:22 AM
Ketis
Jul 23, 2015 12:37 PM
FlowmasterMufflers
Jul 22, 2015 01:29 PM
FlowmasterMufflers
Jul 17, 2015 03:26 PM
Mark_k
Jul 8, 2015 10:44 PM
