did the walbro swap but....
Old Feb 14, 2008 | 01:51 PM
lpguy's Avatar
Default did the walbro swap but....
I got everything istalled but the truck hesitates to start... It will start and run fine but every few times ill turn it over stop then try again then it will start... Any suggestions?
Old Feb 14, 2008 | 02:16 PM
skeet's Avatar
check fuel pressure with fuel pressure guage sounds like youre loosing fuel pressure, which is due to line most likely in fuel tank... it sucks but it happened to me had to lift bed and fix hose i used for fuel pump, cause it would leak by..
Old Feb 15, 2008 | 03:07 AM
lpguy's Avatar
fuel pressure gauge reads 62 psi at idle... i think im just used to the stock pump priming faster. if i turn the key to ign for a sec then start it fires up. Im hoping thats what it is. ill see how it acts
Old Feb 15, 2008 | 06:42 AM
skyhighsami's Avatar
no title here
I had a Walbro on my Typhoon and it took a little longer than normal to crank
Old Feb 15, 2008 | 07:23 AM
skeet's Avatar
good deal hope thats all it is, on another note, when you turn truck off, does the fuel pressure drop over time. if so how much.. it should hold maybe drop a few psi ..
Old Feb 15, 2008 | 07:55 AM
03sierraslt's Avatar
My pressure is 62 idle and when I turn it off it doesnt drop below 56psi even after a nite.
Old Feb 15, 2008 | 08:42 AM
DrX's Avatar
DrX
Sounds like the check valve has been removed from the pump or there is leak in the connection hose. Otherwise you wouldn't have to wait for pressure to build.
Old Feb 15, 2008 | 09:41 AM
Nick™'s Avatar
yeah, you shouldn't have to wait for pressure. we installed a Walbro in white1's truck and besides sounding a little deeper in tone instead of a high pitched whine you wouldn't know the difference, fires right off like a stock truck.
Old Feb 15, 2008 | 09:52 AM
ap2002's Avatar
i noticed the same on mine, i just turned the key to the front for 1-2secs and it fires right up...
Old Feb 15, 2008 | 12:01 PM
95ImpSS's Avatar
formerly 1BADC10 (12/14/2011)
Still... you shouldn't have to wait fot 60+lbs to build. That should be closer to 60 when you shut the engine off (b/c the pump primes the system for a second or two... at least mine does). I can jump in my truck, trun key to crank, and fires right up.... no wait. Hmm... something's dropping pressure enough for you guys to have to wait for pressure to build up.
Maybe my pump flows faster than the advertised 255lph (Procharger Aux Pump). I dunno.
