did some tuning, new ET, sweeeeeet!
Old Nov 26, 2002 | 04:28 PM
  #21
BigTex's Avatar
Default Re: did some tuning, new ET, sweeeeeet!
Here you go Jim:
https://ls1tech.com/ubb/ultimatebb.p...c;f=7;t=008294
Old Nov 26, 2002 | 04:43 PM
  #22
parish8's Avatar
single digit dreamer
yea, i am really thinking about one of those, it would get me by for now and once i upgraded to a bigger pump it would help then also. i think a bigger pump and the boost a pump might just get it done for good.
Old Nov 26, 2002 | 06:12 PM
  #23
Scott(Billy Bob)'s Avatar
you could go really cheap and just add an injector with a resistor wired to a WOT switch so itll only kick fuel in at WOT and not have to worry about grams and MAF and other computers. Just a thought, did this on a turbo callaway Jetta once to try it out <img border="0" title="" alt="[Mad]" src="gr_images/icons/mad.gif" /> fire breathing little sucka <img border="0" title="" alt="[Razz]" src="gr_tounge.gif" />
Old Nov 26, 2002 | 07:26 PM
  #24
parish8's Avatar
DAMN!!!! that sounds like a great idea, i could set the power enrichment so it basicaly doesn't come on till WOT, then hot wire one of the whipple injectors to a WOT switch. then adjust the power enrichment vs rpm on a wide band, seems like that should work well. i could spend the money that i was going to spend on injectors on a wide band 02 set up.
i am pumped up about this, no injectors to make fit, i think it will work. i am going to pass this by the FI guys(harlin) and see what they think.
Old Nov 26, 2002 | 07:39 PM
  #25
BigTex's Avatar
Let me see... ummm... Isn't that what the whipple computer does? In a nutshell, turns on the injectors at WOT above a certain RPM?
I do like the custom, take it your own hands approach. I also like the idea of using those extra whipple injectors you have sitting in a box somewhere. Much cheaper.
Since your current injectors are OK until the upper rpms, you should get one of harlan's rpm switches. Just like a window switch for nitrous. That with a WOT switch and you'd have what you want. The injector turns on only at WOT and above a certain RPM.
Old Nov 26, 2002 | 07:51 PM
  #26
parish8's Avatar
i am not sure how the whipple injectors are controled, i believe there is a program that looks at MAF, rpm, tps then adds fuel, it doesn't know that i have injectors that prety much cover my fuel needs so it will add fuel way too soon. i am worried about lets say 3/4 throttle, before the PE starts working but after the whipple injectors start firing, i think it will go way rich. that may not be a problem though i usualy only go maybe 1/2 throttle max or i go WOT, not much in between.
Old Nov 26, 2002 | 07:54 PM
  #27
XLR8NSS's Avatar
Adkoonerstrator
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by BigTex:
<strong>Let me see... ummm... Isn't that what the whipple computer does? In a nutshell, turns on the injectors at WOT above a certain RPM?
Since your current injectors are OK until the upper rpms, you should get one of harlan's rpm switches. Just like a window switch for nitrous. That with a WOT switch and you'd have what you want. The injector turns on only at WOT and above a certain RPM.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Very good idea there with the window switch/WOT switch setup BigTex. <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
John
Old Nov 26, 2002 | 08:02 PM
  #28
parish8's Avatar
yea, now were talking, i can turn the injector/injectors on at 5500rpm or so and slightly after that pull a little fuel with the PE vs RPM chart. there might be a 100rpm or so where it is a little rich.
D3moN plz
19
Dec 9, 2015 11:14 PM
06 4.8
Aug 21, 2015 11:33 PM
JFortner5
Aug 20, 2015 06:13 PM
Ls3silverado
Jul 31, 2015 04:22 PM
oharajo
Jul 18, 2015 09:24 PM
