did 4.8's have longer cranks?
Old Jul 11, 2011 | 05:10 PM
SmokinHot98's Avatar
Default did 4.8's have longer cranks?
Did the 4.8's in the Express vans w/the 80e's behind have longer cranks? A friend is putting a 4.8/60e combo in his '97 S10.
the is from his '07 4.8 from an Express Van
and this is from my '04 4.8
Old Jul 11, 2011 | 10:06 PM
JFOLM's Avatar
They should all be the same length. The flex plate and spacer should make up for the space. But he is going to a 60e so he would need the 60e flex plate.
Someone correct me if I am wrong.
Your buddy would not want to sell the 80E flex plate and spacer would he?
Old Jul 11, 2011 | 10:14 PM
Camaro Zach's Avatar
take a straight edge and lay it across the bellhousing mounting surface on the block and measure the offset to the crank. Compare it to your motor or post the measurement here and someone can give you a definite answer.
Old Jul 12, 2011 | 06:25 PM
he bought an 80e setup but returned it bc it didn't work
Thanks
03chevytruck
Sep 14, 2015 09:15 PM
FormulaZR
Sep 14, 2015 05:23 PM
vipergtrdj
Sep 11, 2015 05:52 PM
Justin87gn
Sep 10, 2015 12:06 PM
hackrst
Sep 2, 2015 05:27 PM
