Determing push rod length?
Old Jan 25, 2010 | 05:26 PM
1sic03x's Avatar
Default Determing push rod length?
I suppose I'll need a checking push rod but I have 7.4 trick flow push rods, I just checked the preload and I was at 0.085, but I need to be at between 0.020 and 0.060 ideally 0.030 right? How would I go about finding the right length?
Thanks in advance for the help,
Andy
Old Jan 25, 2010 | 09:31 PM
DOA's Avatar
DOA
Read this: It was a sticky in the internal engine section.
https://www.performancetrucks.net/fo...d.php?t=440262
Old Jan 26, 2010 | 07:30 AM
1sic03x's Avatar
Thanks for the link, I had done some more research on it and found the right preload on the LS7 lifters.
Old Jan 26, 2010 | 12:29 PM
aaronmc's Avatar
What length did you end up going with 7.325?
Old Jan 26, 2010 | 04:12 PM
1sic03x's Avatar
I need to go back and double check the preload. But If they are wrong I'll go with the 7.325's since thats whats recommended and my heads are milled .015
Check the classifieds, you might see some nice new Trickflow 7.4 pushrods soon lol.
Old Jan 26, 2010 | 04:32 PM
aaronmc's Avatar
Well I have some TSP 7.4's coming but I'm using LS7 lifters too, so I'm thinking I'm going to need shorter ones also.
Old Jan 26, 2010 | 07:34 PM
1sic03x's Avatar
I think you might be ok, i just checked mine again and I'm at .070-.075, with the heads milled at 0.015
Old Jan 26, 2010 | 07:43 PM
aaronmc's Avatar
This is on an LQ4 with 243 heads. If that matters.
Old Jan 27, 2010 | 01:41 PM
1sic03x's Avatar
I would think you would be ok, seeming that with 7.4 pushrods and heads milled .015 i was at .075
Texas5.3_1251
Mar 5, 2016 08:10 PM
cheyenne383
Nov 13, 2015 09:24 AM
lukn4trbl355
Oct 21, 2015 11:19 PM
sTNT971
Sep 26, 2015 04:22 PM
