define "mild headwork"
valve job, milling
I think once you get into port and polishing and larger valves with different seats then its no longer mild. Even just a good 5 angle job does wonders on these heads.
I call it that b/c the p&p is not professionally done so there is room for improvement. My new heads consist of- valve job, milled, T.R. port and polish. Matt, what more did you do to those heads?
well i'm considering milling my heads just to bump the compression a little but prolly won't bother with anything else unless someone says "hey tony, just cuz i'm bored i'll do a valve job and some p&p for you"
Not much
Angry Silverado
Oct 21, 2015 07:07 PM
Tigger Welder
Oct 1, 2015 08:41 AM
