Decision time, FAST 78mm or LS6?
Well I am going to swap to a car manifold, The question is which one? Either the FAST 78mm or the LS6. I really don't know which way to go, I can get the FAST for $650 or the LS6 for $425. I am kinda leaning towards the FAST, if I am going to do it, then go big!
I think LS6 for the cost/hp reason, I saw an unmolested LS6 go over on tech for $250. If you think you might want to go to a 90mm tb later, then the FAST. The FAST is a three piece and the tops are interchangeable.
I am going to try to use the truck rails and injectors, this way it will be easy. I just got 42lb injectors, so I want to try to use them.
I am pretty sure that the stock truck TB is 78mm to start, Well thats what I was told. Yes I am going to use the stock TB, I am DBW so I don't have a option.
Gadgetized
Jul 7, 2015 04:40 PM
