DBW intake the same as cable operated?
Old Dec 5, 2008 | 08:16 AM
1936 LS1's Avatar
Default DBW intake the same as cable operated?
I need an intake but I already have a DBW TB. Are the earlier intakes physically identical?
Old Dec 5, 2008 | 11:49 AM
budhayes3's Avatar
PT's Slowest Truck
The intakes and bolt patterns are the same.
Old Dec 5, 2008 | 12:28 PM
1936 LS1's Avatar
Thanks. I didn't want to buy an older one and not have it work with my DBW throttle body.
Old Dec 5, 2008 | 12:31 PM
00ChevyScott's Avatar
Wearin' da big hat
only difference is mounting plates for cable TB and cover, and the fuel system is different, but those can be swapped between all of the truck intakes.
Old Dec 5, 2008 | 02:11 PM
bluecajun5.3's Avatar
11 Second Truck Club
they are different.
on a dbw intake there is a nipple on the intake to hook up the hose that comes from the passenger valve cover. on a cable intake there is no nipple so it goes to the tb.
Old Dec 5, 2008 | 02:49 PM
1936 LS1's Avatar
Thank you, BlueCajun. I'll try to get one that's for a DBW setup to avoid any problems. That should be '03 and up, correct?
Old Dec 5, 2008 | 03:12 PM
budhayes3's Avatar
PT's Slowest Truck
Oh crap, sorry man, I was sure they were the same, my bad
Old Dec 5, 2008 | 03:15 PM
1936 LS1's Avatar
No problem. That's why I asked it here on the forum. So many people with different knowledge!!
Old Dec 5, 2008 | 03:32 PM
no problem.
99-02 has a cable tb and 03 and up has dbw.
Old Dec 5, 2008 | 06:15 PM
1Bear's Avatar
Originally Posted by bluecajun5.3
no problem.
That's the straight up easiest way to get the right one, unless you get one from any of the earlier trucks that came with traction control, Denali's or Escalade's that also had DBW throttle bodies before '03.
