Damper, aka Harmonic Balancer........
Old Feb 22, 2018 | 10:13 AM
Mark Johnson's Avatar
Default Damper, aka Harmonic Balancer........
Hey guys- noticed for awhile now that when approaching 3.5k and above I run into what I perceive as ringing from the crankshaft and probably other places too. I've gathered a few points here and there that #1 the factory elastomeric damper frays and wears out and is also 'tuned' for a quite narrow range. So my question to everyone in the know- is an aftermarket damper worth considering? BTW I just turned 150k and the truck is 12 years old..............
TIA
Old Feb 22, 2018 | 07:02 PM
2002_Z28_Six_Speed's Avatar
i'd just get a new stock one. they are pretty cheap on rock auto.
Old Feb 26, 2018 | 10:34 AM
Thumbs up
Thanks- I was starting to lean that way, that's what I'll be doing........
Old Feb 26, 2018 | 11:14 AM
Atomic's Avatar
I have a gauge for that
It's just a pulley. These engines are internally balanced. Resonance with your exhaust sounds more likely.
Old Feb 27, 2018 | 09:45 AM
What would I look at to address exhaust resonance?
Old Feb 27, 2018 | 10:25 AM
Atomic's Avatar
Mufflers, pipe diameter, pipe length, etc. That droning sound you hear is resonance.
Old Feb 27, 2018 | 10:34 AM
It's not drone, it's more like a roughness which is why I believe I can't wind it out like the Denali........
Old Feb 27, 2018 | 10:45 AM
BudRacing's Avatar
Any difference in motor mounts between the two? Solid motor mounts would transfer more of that roughness you're feeling.
Old Feb 27, 2018 | 11:04 AM
Atomic's Avatar
Thats different than a ringing sound. Roughness is probably a misfire for some reason.
Old Feb 28, 2018 | 10:56 AM
Each are stock, I'm starting to conclude the difference in sound damping material between a 2006 Truck and a 2013 Denali...........
94 guy
Sep 1, 2013 02:58 PM
f4tal
Apr 1, 2012 10:06 AM
McKlusky
Feb 11, 2006 03:47 PM
speedy02
Feb 4, 2004 07:59 AM
