2007 lmg cam swap
2007 lmg cam swap
Have a 2007 lmg with 243 heads lifter took out the cam.Friend gave me his ls2 cam out of his corvette was thinking of using it what kind of gains could I see with this cam above the 325hp it already has or will I gain any at all? pros and cons of this swap please
Lots of better options out there for cams if you ask me. Won't be a serious bump in power in a truck motor that does not rev nearly as high or have the same displacement.
With all the other AFM/DoD delete parts you already have to buy, find a better 212/218 cam that would better suit that engine.
It will be worth your time, there are better cams out there but the LS2 is a solid performer and you can use oe LS6 springs, and you get a nice smooth idle...should see 30 HP gain with minor loss of low end...delete the AFM and throw in some new lifters and LS6 springs, worth a weekend of work imo
i work at a gm dealership so i can get a good discount on Gm cams can anyone suggest a good Gm cam.since i have to replace the cam anyways thought that i would add a little horsepower without sacrificing too much that why i was thinking of using the ls2 cam.
That hotrod article also used a Crane Cam grind that outperformed the others torque wise down low. I think it was the 1449511 which is 206-214 .500-.500 114.
The L9H cam is 198-209 .500-.500 115
The LY6/L96 cam is 196-208 .467-.479 116
Your stock camshaft is 193-193 .482-.482 116 - same as Gen III L33.
2010 and later with VVT used a different grind.
The LH9s cam is 191-190 .457-.466 114. I have seen the duration numbers swapped quite often, same for lift but Brian Nutter at Summit Racing figures this is probably the most accurate. This grind is used on many Gen III and Gen IV engines. The L33 made about 10 more horsepower and 15 ft pounds more torque.
turboal1 (12-05-2017)
Removing all the bs and making it as simple as possible will garner the most gains. A tsp stg2 hi lift truck cam would gain you well more than that ls2 cam or any stock cam.
Do it once and do it right i say!
If you need help with parts for the kit, please email me
Rpmspeedtech@gmail.com
