Damned VSC
Old Apr 23, 2004 | 06:28 PM
  #21
Originally Posted by Hit Man X
The kit came iwth 12awg though and is supposedly rated to 35 or 40A I think...
Should I change all my power wire to the batt to 10 awg? The fan wiring should be fine at 12awg as the fans draw about 12-14A each I think...
An inch of protection goes miles in terms of prevention, er or something like that. 10Ga wire is like $5 for 10' at your local autoparts store. For a little more you can get car audio grade wire that is multistrand OFC copper that will probably handle some 30amps just fine. But it's perhaps $1+ a foot.
I think it's the initial draw as the fans start up that draws the most current. Then after that the fans draw a lower amount that will eventually heat up the VSC. The more wire resistance you have, the more heat you generate. So might as well try a lower ga wire...
Old Apr 23, 2004 | 06:33 PM
  #22
Hit Man X's Avatar
Cool deal, thanks for the info!
Looks like I will get my **** together and upgrade that wiring early next week or this weekend. Any particiular brands of wiring you prefer/use?
Old Apr 23, 2004 | 06:38 PM
  #23
Nah just get the autoparts store brand. But if you won the lotto or sumthin go to a car audio dealer and look at their 10ga power wire. Looks nicer, is more fleixble, and can handle a bit more current.
Old Apr 23, 2004 | 10:04 PM
  #24
therock's Avatar
What kit you talking about? If it's Flex-a-Lite I'd call no matter how long it has been. Cry your eyes out. They should get you a new improved unit.
Old Apr 24, 2004 | 12:10 AM
  #25
GMChasLS1's Avatar
Hey Hit Man X glad you got your fans working again. I told you one time that the PCM turns off the fans over a certian MPH but I did some more testing and found out I was wrong. I guess I was monitoring them in too cool of weather. On a hot day they can stay on all the time with the AC.
Old Apr 25, 2004 | 04:49 PM
  #26
Hit Man X's Avatar
Oh thanks for that heads up! As soon as Allen has that 3 relay setup ready, I will be buying one.
BTW...you going to make it to the GTG in May?
Old Apr 25, 2004 | 06:58 PM
  #27
therock's Avatar
What 3 relay setup?
Old Apr 25, 2004 | 07:06 PM
  #28
Z1500's Avatar
What is the need for VSC? Why can't it just be on or off? Seems like one relay per fan to cut down on load per wire/relay and triggered by the ECU would be the best. Where did I see the wiring instructions on someones website? It showed how to wire up the LS1 fans.
Kevin
Old Apr 25, 2004 | 07:16 PM
  #29
Hit Man X's Avatar
therock... Allen's making some 3 relay setups that will run the fans in parallel and series loads for when you activate fan turn on via the PCM. Like how the OE F-bod and C5s have fans wired up.
Z1500... you don't really need or want fans On or Off. It causes charging spikes and isn't needed to max cool at the low speed. Wiring isn't the problem for me, the included wiring in the VSC does fail in time.
Old Apr 26, 2004 | 05:12 AM
  #30
GMChasLS1's Avatar
I was going to make the first gig in May, the 9th, but the Snap-On track event is going on the 16th!
jscherbs
Mar 24, 2017 07:20 PM
Wolftrk99
Oct 2, 2015 08:17 AM
RS/SS 4.8
Sep 17, 2015 09:17 PM
TURBHOE
Aug 27, 2015 09:09 PM
