Damn pacesetters!
Originally Posted by UnrthdxDream
sweet! thanks guys got that side in... and the passenger side... has anybody had any luck using the gaskets that pacesetter sends with the headers?
-Lurius
dealer was closed... damn small towns... i did get some fel pro gaskets... said screw the copper ones... but now im screwed on my steering shaft... it was upside down and i taped it.... but because it was upside down... and the bottom is heavier... it turned itself over i guess when i was climbing around in the engine bay and i dont know which way it fell.... lol... if it fell back to the left or to the right... i feel so dumb right now....
well i went with my instict as to which way it fell and corrected it... i have the y pipe slid on now as well... only thing is the y pips is really close to the front driveshaft... as in currently i cant fit a finger between the driveshaft and the pipe... has anyone seen this problem before? i do have the tranny lifted up a lil bit (2-3 inches) and i guess that is making the headers have more of an upward angle... hopefully that will change when i bolt the crossmember back in...
Now...get back under there and use a Body hammer or heat the 3rd primary on the driver side and dent the primary in about a fourth os an inch. This will allow you to clear the header with your front driveline. Now ratchet a "come-along" around the header collector and anchor it to a pillar in the building or something. Then tighten it up, enought to pull the collector and header over to the side of the truck about 1 inch. Then weld up your Y pipe. This will help it hold it's shape when you let it go.
ive been installing headers, mainly pacesetters on camaros for a long time. ive never had a gasket problem using felpro, the supplied gaskets, the new supplied copper gaskets, or the stock gm gaskets. i never have to check the bolts torque either. i believe all the problems people have with gaskets is an installation error.
yeah 2 days... 300 miles later the fel pro gaskets aren't leaking... i checked the header bolts and they are still tight. only thing is i am still experiencing a lil bit of an exhaust leak at the drivers side collector.. have the easyseal i bar clamps on there cause i dont have a welder.. the leak cant be much cause it seems to dissappear once the truck has been heated up and running for like 30 mins.. i cant feel anything coming out at least.. any tips? already have the bolts on the clamps at the 60 ft-lbs they recommend...
jscherbs
Mar 24, 2017 07:20 PM
