Damn pacesetters!
Old Apr 14, 2007 | 04:13 PM
UnrthdxDream's Avatar
Default Damn pacesetters!
ALright so I am in the middle of installing my headers after spending 3 hours getting the stock crap off (man 5 years of colorado winters suck when your trying to get a stock y pipe off...) and now the drivers side long tube doesnt wanna fit up from the bottom. i took out the spark plugs.... do i have to take off the steering shaft too? i thought from the bottom was the best way to do it? moddoo's writeup even made it sound like the drivers side was easier.... i just wanna get this crap done and go 4 wheeling today dammit! any help would be appreciated..
Old Apr 14, 2007 | 04:18 PM
Scott Mills's Avatar
Both sides of my headers went in through the bottom with plenty of room to spare.
Old Apr 14, 2007 | 04:19 PM
so you didnt have to remove the steering shaft? ****!
Old Apr 14, 2007 | 04:20 PM
Lurius's Avatar
Try this on driver side.. Disconnect the red power junction and move it away. Disconnect the steering shaft and move it away. I did this and that header went straight in! The passenger side was a pain for me though.
-Lurius
Old Apr 14, 2007 | 04:22 PM
KevinF56's Avatar
i disconnected the steering shaft.
Old Apr 14, 2007 | 04:24 PM
alright... i do have the back of the transmission jacked up a lil bit with a 2x4 holding it off of the torsion bar cross brace because i took the transmission k member out.... could that be angling the engine and causing my problems?
Old Apr 14, 2007 | 04:26 PM
and how do i remove the steering shaft? lol is it just the big bolt right in the middle of the shaft or do i have to remove it form the end by the steering box?
Old Apr 14, 2007 | 04:39 PM
Derek @ EDO's Avatar
FormerVendor
remove the bolt in the middle of the shaft and then pull up on the shaft that goes through the firewall!
Old Apr 14, 2007 | 04:59 PM
KevinF56's Avatar
tape your steering wheel in place if you remove the steering shaft. you dont want the steering wheel spinning because it can cut wires and stuff.
Old Apr 14, 2007 | 05:24 PM
sweet! thanks guys got that side in... and the passenger side... has anybody had any luck using the gaskets that pacesetter sends with the headers?
