damn
Old Oct 6, 2010 | 10:36 PM
  #51
Atomic's Avatar
I have a gauge for that
because I didnt have as much pressure as I would like. I had already put in the heavy oil before I cut open the filter to see if that would fix it.
No I havent pulled the cover yet.
Old Oct 7, 2010 | 06:48 AM
  #52
oldred95's Avatar
Lack of pressure is because of a lack of restriction. Did it never have good oil pressure or did it start out good and gradually get lower?
Old Oct 7, 2010 | 09:13 AM
  #53
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
Originally Posted by oldred95
I realize that but it would have to balloon a lot to do that. Usually you can push the converter back about 3/16 of an inch before it bottoms on the hub. It would have to balloon enough to take up the end play then push on the crank. Doesn't seem too likely. Besides that shouldn't have anything to do with lockup like was mentioned earlier.
It quite a bit more often than you think, not saying thats what happened here since he was using a quality converter. Since Ive been on this site I can think of 2 or 3 that have had this happen to them, seems to be most prevalent with the stock converter or modified stock converters. If you have that much play per PI's instructions youre suppose to shim the converter anyway. 3/16 is a lot when you consider the dogs on the converter that engage the pump are only cut maybe 5/16ths deep.
Old Oct 7, 2010 | 09:26 AM
  #54
Atomic's Avatar
Yes, pressure was fine when I first ran the engine and gradually got worse.
Old Oct 7, 2010 | 11:06 AM
  #55
Sc00by's Avatar
Originally Posted by MikeGyver
Maybe on a steam engine, or something else from the 1800's, but the most you should see from break-in of a modern engine is darkening of the oil. Don't forget, he lost oil pressure. The only place that metal contacts metal is the rings and the cylinder walls.
Please don't even you follow your own advise, with loss of oil pressure and bearing material (any amount) in the filter, severe engine damage is right around the corner. I doubt it would have went another thousand miles (even with a new filter ).
Woops....missed the lost oil pressure part.......damn.
Old Oct 7, 2010 | 11:20 AM
  #56
Atomic's Avatar
I took the valve cover off this morning and the rockers and springs look brand new (as they should) and didnt see any sort of material in there.
....also discovered my AC belt is shredded, good thing its already cooled off here
Old Oct 8, 2010 | 12:45 AM
  #57
Atomic's Avatar
Made it home fine tonight after a 200 mile drive...
Fun starts in the morning.
Old Oct 8, 2010 | 01:15 AM
  #58
pewterliftedz's Avatar
glad u made it safe buddy... keep us informed on whats up...
Old Oct 8, 2010 | 01:20 AM
  #59
AKlowriderZ71's Avatar
11 Second Hall Moniter
Reading this story makes me think of this.
Old Oct 8, 2010 | 10:43 AM
  #60
Atomic's Avatar
haha, pretty much
Im already doing better than last time, tc bolts came off without a problem, although the flexplate felt weird while rotating it to get to all of the bolts....
