damn
Old Oct 5, 2010 | 12:16 AM
  #21
AKlowriderZ71's Avatar
11 Second Hall Moniter
Not familiar with how those are built. Do they use a billet cover?
Old Oct 5, 2010 | 12:20 AM
  #22
Atomic's Avatar
I have a gauge for that
Yep, billet cover
http://www.converter.com/vigilante.htm
  #23
1FSTGMC's Avatar
formerly 2low4nd (11-08-2011)
Damn, thats crap luck, what the heck, with so few miles.
Old Oct 5, 2010 | 12:29 AM
  #24
Then I really doubt it ballooned on you.
Old Oct 5, 2010 | 08:18 AM
  #25
NightmareTBSS's Avatar
Sorry to hear that Richard...Did you find anything out last night?
Old Oct 5, 2010 | 08:31 AM
  #26
Sc00by's Avatar
Damn! I know it has the copper look but with the few miles that are on the engine do you think it could be from the break-in process? I would put a new filter and run it another 1k easy and cut the new filter open again. Maybe im too optimistic but if you don't have any funny noises or sounds and the truck is running fine its worth a shot. Just keep a close eye on it. I have always liked your truck Atomic. It hurts me to see this.
Old Oct 5, 2010 | 09:07 AM
  #27
Gadgetized's Avatar
That is bearing material for sure (I assume you already knew that). What are you using for a crank? Did you use the bearings that the crank manufacturer called for? Like using regular bearings on a crank that should have race bearings. Pull a valve cover and see if you have the same bearing material where the oil sits by the studs or bolts.
Old Oct 5, 2010 | 09:14 AM
  #28
MikeGyver's Avatar
Originally Posted by Sc00by
Damn! I know it has the copper look but with the few miles that are on the engine do you think it could be from the break-in process? I would put a new filter and run it another 1k easy and cut the new filter open again. Maybe im too optimistic but if you don't have any funny noises or sounds and the truck is running fine its worth a shot. ...
Maybe on a steam engine, or something else from the 1800's, but the most you should see from break-in of a modern engine is darkening of the oil. Don't forget, he lost oil pressure. The only place that metal contacts metal is the rings and the cylinder walls.
Please don't even you follow your own advise, with loss of oil pressure and bearing material (any amount) in the filter, severe engine damage is right around the corner. I doubt it would have went another thousand miles (even with a new filter ).
Old Oct 5, 2010 | 09:23 AM
  #29
Atomic's Avatar
The one I cut open was the third oil filter ive used on this engine, so there shouldnt have been any bearing material in there.
The crank is a forged K1 stroker crank, and the shortblock was already assembled when I bought it. Pulling the valve cover is a good idea, ill do that.
Old Oct 5, 2010 | 10:47 AM
  #30
double047's Avatar
14 Second Truck Club
Damn sorry to hear about your troubles, keep us updated and good luck!
