cutting cats off
Old Nov 23, 2004 | 11:58 AM
BigKID's Avatar
That is the cat over-temp protection. Basicly it really richens up the afr when it sees you cats getting overly warm during PE mode (wot).
All the rear o2's do is monitor the effeciency of the cats. Without them, the pcm will throw a code but will not hamper performance what so ever.
John.. if you have them cut off, do not waste your money on sims. I will just add that to the list of things I am going to have them do to your predator tune.
Old Nov 23, 2004 | 06:46 PM
goshawk23's Avatar
Truck addict
ok kenny consider it a done deal. i really appreciate the help with that handheld.
Old Nov 23, 2004 | 08:54 PM
CoonToot's Avatar
Originally Posted by F8L Z71
When you cats start getting overheated the PCM will dump more fuel to aid in cooling them down.
Well I just learned something new (again)!
Is there a specific temp sensor for the cats? If not, how does the PCM determine that the cats are overheated?
Old Nov 24, 2004 | 10:23 AM
bourbeaugmcx's Avatar
could that explain why my gas mileage suck right now? i didn't beat on it for a long time and got like 15 mpg?wtf
Old Nov 24, 2004 | 10:35 AM
Scream's Avatar
MOOBIES Moderator
When you get rid of the cats, do you get rid of ALL of the O2 sensors? Mine are rattling and driving me NUTS. Figured it's about the same $ to cut them off as replace the O2s.
Old Nov 24, 2004 | 11:12 AM
F8L Z71's Avatar
EXACTLY!
You're LTrims usually go way out of wack if you don't re adjust fuel after removing your cats.
Scream, you're kidding right? LOL
Just the rear o2s can be deleted as they are no your primaries. Your front ones should be replaced and kept in good condition as your gas milage or motor will end up taking a dump if you don't.
Old Nov 24, 2004 | 11:35 AM
Scream's Avatar
MOOBIES Moderator
No, I was serious. But thanks for the answer. It's the front ones that are rattling, so that won't do any good. Dangit.
GMCtrk
Oct 5, 2015 11:18 AM
JordanH
Oct 3, 2015 03:59 PM
BlownHD
Oct 3, 2015 12:24 PM
02AWDAWSDenali
Oct 1, 2015 05:08 PM
