Custom Y-Pipes
Old Sep 3, 2009 | 11:53 AM
SILVERBIRCH's Avatar
Default Custom Y-Pipes
I will be doing some Pace Setter Lt Headers on my crew cab pretty soon and was wondering if any of you guys with crew cabs have any custom y pipes or the pace setter y pipe on if so please post pictures or provide some feed back on them i would like to get some ideas for this i will be running them with a Borla XR1 In/Out: 3'' Body Length: 16''
Old Sep 3, 2009 | 12:44 PM
Mangled03gmc's Avatar
Baltimore Whore
Is your truck 4wd???
Old Sep 3, 2009 | 12:55 PM
2wd forgot to mention that
Old Sep 3, 2009 | 01:01 PM
Baltimore Whore
I did a custom one on my truck, cut up another Y pipe to make it work, should be the same as yours even though you have a CC. However I did do my crossover pipe behind the trans member..
Old Sep 3, 2009 | 01:04 PM
RandomHero's Avatar
If I remember right you're in Austin. I have an extended cab, but there is a place in Dripping Springs called L&L muffler. They did a great job on my ypipe. I had them weld some flanges on my existing ypipe and tuck it up above the frame.
Old Sep 3, 2009 | 01:24 PM
I am in Houston i just updated my profile details lol...
Old Sep 3, 2009 | 01:25 PM
ap2002's Avatar
contact wheatley, his pacesetters and Ypipe have flanges welded on like "randomhero" mentioned, for easy removal.... I still regret not doing mine like that, now my ypipe is all banged up..
Old Sep 3, 2009 | 01:29 PM
RandomHero's Avatar
I love it. It makes changing torque converters or dropping the transmission a walk in the park. I just have a simple 3 bolt triangular flange with a gasket. No leaks and they're at least 1/2 and inch thick so no warping.
Old Sep 3, 2009 | 03:04 PM
BlackGMC's Avatar
Resident Retard
Here are a couple of exhaust y-pipes have i done.
Exhaust #1
Exhaust #2
Exhaust #3
Exhaust #4
Old Sep 3, 2009 | 03:09 PM
WOW!!! those look great have you done any for an 06 CC like mine.
