Custom Y-Pipes
I will be doing some Pace Setter Lt Headers on my crew cab pretty soon and was wondering if any of you guys with crew cabs have any custom y pipes or the pace setter y pipe on if so please post pictures or provide some feed back on them i would like to get some ideas for this i will be running them with a Borla XR1 In/Out: 3'' Body Length: 16''
I did a custom one on my truck, cut up another Y pipe to make it work, should be the same as yours even though you have a CC. However I did do my crossover pipe behind the trans member..
If I remember right you're in Austin. I have an extended cab, but there is a place in Dripping Springs called L&L muffler. They did a great job on my ypipe. I had them weld some flanges on my existing ypipe and tuck it up above the frame.
i just updated my profile details lol...
contact wheatley, his pacesetters and Ypipe have flanges welded on like "randomhero" mentioned, for easy removal.... I still regret not doing mine like that, now my ypipe is all banged up..
I love it. It makes changing torque converters or dropping the transmission a walk in the park. I just have a simple 3 bolt triangular flange with a gasket. No leaks and they're at least 1/2 and inch thick so no warping.
