critique these cam specs for a 4,400lb truck
Old Sep 5, 2012 | 10:11 PM
silverz28camaro's Avatar
Default critique these cam specs for a 4,400lb truck
219/227 .607/.614 112
LS1 Dodge Ram with 3.90 gear 30in tire, 1998 LS1 with ls6 manifold and longtubes
looking for a cam that will give more low end tq and hopefully more peak power as well.
I have a Yank sstb 9.5in 3600 stall (awesome BTW) I can mill the heads if I have to...so what might be best for pump 93 11:1?
Old Sep 5, 2012 | 11:23 PM
Whitecrewcab's Avatar
I think it will work good, I have a 218/224 in my crew cab and a 3000 converter. Your truck is lighter with a bigger engine and more stall.
Old Sep 5, 2012 | 11:32 PM
AndysC3's Avatar
go big or go home lol. thats a decent cam for a mild ls1. would be fun to drive. why such a big split?
Old Sep 6, 2012 | 12:20 AM
I'm not sure why on the split...someone offered it to me and I have never played around with cams in a truck before...maybe for nitrous? If so perfect I have a HSW plate setup on it anyway
Old Sep 6, 2012 | 01:40 AM
AndysC3's Avatar
well if you ever decide to use a different cam hit me up. I could have a use for it lol
But it would work well in a LS1
Old Sep 6, 2012 | 02:08 AM
stock48's Avatar
9 Second Truck Club
Id go a little less split and tighter lsa for Na, but it will like the n20.
Old Sep 6, 2012 | 03:46 AM
Preston129's Avatar
What heads, 241s? I bet it'll make it's power around 5400 RPM, so I wouldn't expect much low rpm torque (relatively), but with 3.90 gear, 30" tire and 3600 stall speed I think it'll get to the power pretty well.
Old Sep 6, 2012 | 06:40 PM
sand man's Avatar
+1
I have a 219/222 .607/.602 111+4 its a torquy cam on my 6.0
it was a custom for a 5.3 future stall. but with the new motor i dont think it needs a stall it burns tires from a stop and lunches in 4wd alot better than my 5.3
5.3 has a 9.9:1 and 6.0 has a 9.7:1 CR so youll have better results with 10.5 CR +5.7 + light truck
mine sets at ~ 5600+
5.3+cam on a dyno jet it did 365 whp 369wtq with 91 gas I hope it gets me to 400+ with the 6.0
Old Sep 6, 2012 | 06:49 PM
AndysC3's Avatar
I have a 227/235 .614/.621 113 in my Lq4 and make max torque around 5200-5300rpm. And max power at 6900. Lol.
Old Sep 7, 2012 | 10:39 PM
sand man's Avatar
yours isnt exactly " N/A" now is it?
do you have a dyno graph?
wrb002
Aug 31, 2015 12:00 PM
black6spdz
Jul 16, 2015 01:32 AM
GRRR65GTO
Jul 10, 2015 08:27 PM
NuckenFuts
Jul 9, 2015 08:45 AM
