crank pulley removal help!
Old Oct 8, 2005 | 08:39 PM
drkblusierra's Avatar
Default crank pulley removal help!
im trying to get the crank pulley off with a three prong puller with no luck whats the best placement of the puller on the pulley? already broke the outside lip and no luck getting it to stay seated on the pulley. thanks.
Old Oct 8, 2005 | 09:07 PM
It's been a while,but I used a 3 prong puller and adjusted the prongs to go inside the pulley.I hope you aren't going to reuse the pulley with a broken lip.
Old Oct 8, 2005 | 09:40 PM
no got some asp pulleys, i tried the inside of the pulley too, guess if it worked for you i just need to keep working at it. thanks
Old Oct 8, 2005 | 10:20 PM
Nick™'s Avatar
I've seen it done usually on the inside rung of the pulley
Old Oct 8, 2005 | 10:52 PM
TurboGibbs's Avatar
Mine had 3 flat spots on the inside of the pulley just for the puller. get a light behind the pulley when installing.
Old Oct 8, 2005 | 11:57 PM
bluecajun5.3's Avatar
11 Second Truck Club
Old Oct 9, 2005 | 12:30 AM
FarmerBeau's Avatar
Sexy Party Mod
On top of the placement of the puller on the inside slots made for the puller, put a socket on the center threaded peice of the puller to get a better hold. I used a can of the computer cleaner compressed air in a can $hit. I turned the can upside down so the liquid would come out rather than the air. if you freeze the crank pretty good it comes off easier. I know that it sounds a bit whacky but i think it will shrink the crank a thousanth or two which can make it a bit easier. it took me and a few friends 45 minutes to get the bitch off and most of it was trying to figure out how to place it. if i were you i would start looking for a new pulley because it is your damper which does balance your motor. if you are missing pieces you might throw off the balance. just a thought.
Old Oct 9, 2005 | 09:44 AM
CHarris's Avatar
Thats a good idea with the freezing. A friend of mine showed me a similar trick for putting the pulley back on... Use a torch on the pulley center for about 2 minutes and it'll slip right into place. No pushing, no banging, no problems
Old Oct 9, 2005 | 10:10 AM
TurboGibbs's Avatar
Coming off is easy. on the heating it up with a propane torch to install. Just put a little grease on the snout to help out.
Old Oct 9, 2005 | 10:48 AM
ktmrider's Avatar
Use the Chrysler model 3 jaw harmonic balancer puller on the INSIDE tabs ( closest to the crank snout ). Works perfectly on the stock pulley.
You can "rent" them for free at Autozone or Checker with a security deposit.
SlvrSierra4.8
Oct 1, 2015 09:39 PM
1slwgto
Oct 1, 2015 01:51 PM
FormulaZR
Sep 14, 2015 05:23 PM
Justin87gn
Sep 10, 2015 12:06 PM
