Crank Pulley Part#
Old Dec 10, 2002 | 03:27 PM
14 Second Truck Club
Default Crank Pulley Part#
Does anyone know where to get just the ASP Crank Pulley? Is it worth the time and money? <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
99 ext. cab silverado 5.3
3.42 (stock)
K&N FIPK
Jet PCM
True Dual 40 Series Flowmasters
160* Powerstat
Taylor Spark Plug Wires
GMS Mass Airflow Sensor
Old Dec 11, 2002 | 02:06 PM
eallanboggs's Avatar
Default Re: Crank Pulley Part#
TruckPerformance.com has it at a good price. The pulley is smaller in diameter and weighs about 1/2 as much as stock. It allows the crank to spin up faster and reduces the load on the engine from your accessories. It works. You notice the difference right away. I bought a 16X2X120mm bolt to get the ASP pulley started onto the crank snout. That helps because you know you have enough threads in the crank before the bolt heads bucks up against the pulley to push it onto the crank. You need to put a BIG flat washer on the longer bolt because they don't come with a built in flat washer like the GM crank bolt does.
RustyD
May 23, 2016 07:04 PM
SSpeeDEMONSS
Oct 3, 2015 08:21 PM
Lthompson
Oct 2, 2015 12:45 AM
old motorhead
Sep 29, 2015 08:22 PM
trxmxzx
Sep 29, 2015 07:42 AM
