Cowl Induction = lower IAT's??
Old Feb 10, 2006 | 12:28 PM
dhpro's Avatar
Default Cowl Induction = lower IAT's??
Anyone have any experience with this. Looking for ways to lower underhood temps and hopefully IAT's. R/
Old Feb 12, 2006 | 02:34 PM
Yelo's Avatar
IAT's will only be lowered if the air entering the engine is cooler....a cowl hood really doesn't affect this
Old Feb 12, 2006 | 02:55 PM
TIM Z's Avatar
11 sec. Truck Mod
when chevy high perf. put a cowl hood on the SS blown silverado, they reported a 5 degree temp drop on under hood temps. i guess every little bit helps.
Old Feb 12, 2006 | 05:14 PM
YenkoST's Avatar
I've seen more than 5 degrees on my engine. In the summer, the cowl makes a biggggggg difference in SE GA at least.
Old Feb 12, 2006 | 05:39 PM
TIM Z's Avatar
11 sec. Truck Mod
good news! when i installed my goodmark hood i didnt put the factory insulation back on, did you and does it make a difference?
Old Feb 12, 2006 | 06:41 PM
YenkoST's Avatar
I didn't use it....I just painted the underside of the hood and put it on. No insulator here. With the cowl, I can see a lot of hot fumes coming up through it. I probably had closer to 15 degrees drop of underhood temps or more. Helps my intake stay cooler as well.
Old Feb 12, 2006 | 06:44 PM
TIM Z's Avatar
11 sec. Truck Mod
yeah, i got mine painted and clear coted too, and i though it would help heat to escape better without the insulation, also the stamped GM logo under side is cool too!
Old Feb 12, 2006 | 07:58 PM
TurboGibbs's Avatar
If you make the cowl induction hood functional it should lower IAT's. Any kind of hood scoop that is not functional is in my opinion.
Mr. Chainsaw
Oct 18, 2015 08:00 PM
vmaxpro
Sep 28, 2015 11:10 AM
dantheman1540
Sep 18, 2015 03:03 AM
TAPyvehc93
Sep 17, 2015 10:10 AM
Roody0209
Sep 17, 2015 09:06 AM
