could my nelson tune be screwed up?
Old Jun 19, 2005 | 09:11 AM
dandaman's Avatar
Default could my nelson tune be screwed up?
My truck has been tripping the SES light. I took it over to be scanned and the code was for the oxygen sensor voltage out of range. I replaced all four sensors and reset the computer. Once it cycled again the light came back on and the code was the same thing only this time it was for the two front sensors. When we drove it with the scanner hooked up the voltage readings were exactly what they should be on all sensors. My mechanic that was helping me seems to think that something is glitched with my program. Do you think I should ask for a new tune? I did put on a corsa exhaust since my last tune so a new tune could adjust for that also, but I would like to find the root of my trouble before I add more possibilities to the mix. Thanks
Old Jun 19, 2005 | 09:14 AM
BigBlockChev572's Avatar
If you just installed the tune and SES lights are occuring you need to let Allen now, he will fix the problem. You shouldn't be throwing an SES light when a new tune has just been installed.
Philip S.
Old Jun 19, 2005 | 09:16 AM
bud8fan's Avatar
get with allen and tell him whats going on...he'll fix you up....bottom line is he cant fix it if he does'nt know whats going on
Old Jun 19, 2005 | 09:17 AM
dandaman's Avatar
the tune is about a year old. I have been tripping this code for about 2 months.
Old Jun 19, 2005 | 09:19 AM
one03sierra's Avatar
Formerly one92rs
Talking
how long has the tune been in. did it start this after the exhaust mod? you say the readings are normal on a scanner. the scanner gets the readings from the pcm. i would look into the exhaust and make sure there are no leaks at all.
Old Jun 19, 2005 | 09:30 AM
dandaman's Avatar
the problem was there before I got the exhaust in. I was going to wait till I found the problem before installing it but I couldn't wait to hear my truck with the corsa. I think I will give Nelson a call and see what he thinks. This is definitly killing my performance. Thanks
Old Jun 19, 2005 | 09:50 AM
Deckhand's Avatar
Are you sure its not the rear o2's for the cats?
Old Jun 19, 2005 | 11:43 AM
dandaman's Avatar
well the sensors are all brand new and before I reset the computer it said they were all bad. After reseting the computer the code was only for the front two. But all of the sensors show as being in the right voltage range....
Go5.3tt06
Sep 12, 2015 09:29 AM
Ammadien
Jul 22, 2015 08:50 PM
ullose272
Jul 19, 2015 04:14 PM
01sierraon22s
Jul 8, 2015 11:26 AM
GreyChevy
Jul 7, 2015 08:57 PM
