Corvette Servo Installation
Old Jan 31, 2003 | 03:06 PM
Default Corvette Servo Installation
Ok, I've had my truck on ramps for the last hour and a half and as far as I've gotten is removing the heat sheld. How in the heck do you remove the servo cover? <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" /> I'm about to pay someone to do it!!! <img border="0" alt="[bang head]" title="" src="graemlins/gr_banghead.gif" />
Old Jan 31, 2003 | 03:36 PM
graygmc's Avatar
Default Re: Corvette Servo Installation
yea anybody have any good instructions. i have had a super servo sitting in my room for over a month. one of these weekends i'll get around to putting that bitch in.
Old Jan 31, 2003 | 03:48 PM
Try this one on for size guys:
http://sethirdgen.org/servo.htm
Should help you out some, any questions let me know!
Ryan
Old Jan 31, 2003 | 03:58 PM
Yeah, I looked at that site before I attemped anything. The cats are in the way so it makes it very difficult to use anything to pry the cover off. I used a screwdriver and even that is almost too large to use. It sounds like it'll take some force to pry it loose. A screwdrive just isn't going to cut it! <img border="0" alt="[bang head]" title="" src="graemlins/gr_banghead.gif" />
Old Jan 31, 2003 | 04:30 PM
FarmTruc's Avatar
Performance Trucks Sponsor
remove the crossmember, that may let the trans fall a little bit
Old Jan 31, 2003 | 04:57 PM
99GMC Can's Avatar
I use a large prybar and push against the floor. The ring comes out with a little coaxing. Then its easiest to cut the o-ring that seals the cover. Usually they'll sell you a o-ring with the servo. When you put it back in make sure it doesn't twist.
It is also recomended that when changing the servo to make sure the drive shaft still moves freely after installation. Put it all together without the seal. It has something to do with the band being too tight
Old Jan 31, 2003 | 06:23 PM
GoldenVelvet's Avatar
The speed shop in town charged me $70 parts and labor to do the install. Hey for $70 I have it done and someone to blame if it goes wrong.
Old Jan 31, 2003 | 11:36 PM
CashDudeHomie's Avatar
<img border="0" alt="[bang head]" title="" src="graemlins/gr_banghead.gif" /> Before you give up try this. Here is what you do. You see how the hole it is in is round and there are 2 slots in the edge of this hole. Take a small flat head screw driver, and put it as far back into the slot of the hole and push it to remove the retaining ring. There is a ring around the inside holding the cap on and you must wedge the screwdriver tip in the remove this ring. If you already have the retaining ring out and the cover is still stuck in, you should be able to do the same thing to pry it out. With the rubber seals, it is kind of vacuum sealed.
<small>[ January 31, 2003, 11:39 PM: Message edited by: CashDudeHomie ]</small>
X_Racing1
21
Mar 30, 2016 02:37 PM
pittman
Jan 19, 2016 07:06 AM
spiritfish
Aug 23, 2015 09:58 PM
lycominghunter
Aug 15, 2015 12:26 PM
Ferocity02
Aug 7, 2015 08:50 PM
