contemplating electric fans
Old Mar 1, 2006 | 09:17 PM
rubrhammer's Avatar
Default contemplating electric fans
I'm looking at ways to free up or gain some low end and mid range tq for when I'm towing the camper. The Gibson shorties made a little improvement but not nearly what I'd like to have. (I did see a mileage increase though.) Anyone know how much power is robbed by the stock fan? I thought I heard 10 hp somewhere. I'm confident that I could make some LS1 fans work. I used to fab shrouds and build prototype radiators for GM for years. what I don't know is how they are controlled. From what I'm reading here it sounds like they are computer controlled. Will a 2000 silverado ecm drive them?
More ?s later.
Old Mar 1, 2006 | 09:19 PM
v8
17,16,15,14,13,12,11 Drvr
yes with the right tune you can use the pcm to run the fans, you will get close to 20hp on very hot days, on cold days maybe 5hp, yes alot people use the ls1 fans. good luck.
Old Mar 1, 2006 | 09:23 PM
ap2002's Avatar
yes, you can make the LS1 fans work... pm "white1" for a fan harness that will hook up straight to your pcm...
Old Mar 1, 2006 | 09:28 PM
rubrhammer's Avatar
Can any of the LS1 wiring or relays be used?
Old Mar 2, 2006 | 05:44 AM
ap2002's Avatar
I would say no, but dont quote me on that.... best way to go is with a harness....
Old Mar 2, 2006 | 08:12 AM
dkota196800's Avatar
I talked to nelson performance and they said if i put in there harness i could control the temp settings with a programmer( i have Diablo Sport) even being as old as it is. Any one got any input? thanks.
Old Mar 2, 2006 | 08:14 AM
white1's Avatar
You will also need to have the fans "turned on" in the PCM like V8 said. Pretty mutch the only thing Im aware of that you can use from the car would be the plugs that plug into the fans. You might could re-use the relays also, but I havent looked at a car fan harness. Ill be more that happy to fix you up with one though
Old Mar 2, 2006 | 08:52 PM
rubrhammer's Avatar
thanks guys
Old Mar 2, 2006 | 09:21 PM
METALMULISHA777's Avatar
get a nelson tune / ls1 harness mine works awesome its like factory .. almost
SS94S10
Jan 3, 2019 01:57 PM
CD82
Oct 23, 2015 07:32 AM
Wrecker 426
Sep 30, 2015 09:39 PM
old motorhead
Sep 29, 2015 08:22 PM
Alvin@PCMofNC
Sep 3, 2015 06:38 AM
