Conflicting dyno numbers?
Old Apr 16, 2004 | 02:01 PM
Default Conflicting dyno numbers?
I have noticed that several companies chasis dyno numbers seem to conflict with each other. Hypertech's numbers for a 2000 GM 2wd is 256. However, JBA header's numbers is 198; JBA didn't say that it was a two or four wheel drive. So which numbers should I believe? What does a stock 2wd Silverado put down on a chasis dyno?
Old Apr 16, 2004 | 02:03 PM
MacADaYear's Avatar
4.3 ? 4.8? 5.3?
Old Apr 16, 2004 | 02:07 PM
5.3 vortech
Old Apr 16, 2004 | 02:10 PM
BlownChevy's Avatar
blownerator
25 Year Member
Dyno's are like *****.....No two are the same!
Old Apr 16, 2004 | 02:12 PM
Flyer's Avatar
LOL ... nicely put
Old Apr 16, 2004 | 03:09 PM
Hit Man X's Avatar
Hell dynos read differently on the same car on the same day within the same hour. Depends on the dyno brand, it's load, airflow to the motor vs gear being pulled, etc, etc.
Old Apr 16, 2004 | 03:11 PM
one is rwhp the other is some imaginary number estimated at the crank.
Old Apr 16, 2004 | 03:17 PM
Cmarsh93z's Avatar
I just dynoed a stock 2000 GMC , 5.3 with 100k on the clock. 244rwhp before tuning, 253 after tuning...286 torque. Peaked around 5600 rpm! Just a data point for ya!
Chris
Old Apr 16, 2004 | 03:38 PM
FarmTruc's Avatar
Performance Trucks Sponsor
Mostly depends on the brand of dyno, go with an inertia only dyno , like the dynojet and you'll get nice high numbers, usually inflated about 10-15 %. Great numbers for sigs.
Run it on a loaded dyno, like the superflow or mustang dyno and then you'll get real world hp your truck is putting to the ground.
Running on both is a night and day difference.
I only put 298 or so on a mustang dyno, and about 331hp on a dynojunk, oops, dynojet.
One is like free spinning your tires, the other is like you're pulling a trailer.
later,
allen
Old Apr 16, 2004 | 03:44 PM
Flyer's Avatar
Was that on or off the bottle?
