Compression test questions/results
Old Dec 29, 2010 | 10:51 PM
1SlowHoe's Avatar
Destroyer of Transmissions
Default Compression test questions/results
What happpens if I forget to pull the fuel relay during a compression test?
Does it affect the numbers?
How long should I wait to start it?
What if I start it too soon? BOOM? Lol...
Destroyed several plug wires trying to get them off
Anyway these were the results, thoughts?
Old Dec 30, 2010 | 12:00 AM
Atomic's Avatar
I have a gauge for that
Looks normal to me. Hold the pedal to the floor and try to start it for a few seconds. When the computer senses more than 80% throttle during cranking it will cut the fuel allowing you to clear the cylinders. It might start briefly from residue fuel left in the cylinders, but should die quickly then be fine after that.
Old Dec 30, 2010 | 10:03 AM
BlownChevySS's Avatar
Those are all good numbers man. The cylinders shouldn't be flooded and whatever fuel is in there will just burn off when you go to start it.
Why did you have to run a compression test? Was the truck lacking power?
Old Dec 30, 2010 | 12:48 PM
1SlowHoe's Avatar
I will be selling the engine/112 blower soon and I wanted to make sure it was good to. Hate to sell it and it have an issue.
Old Dec 30, 2010 | 04:15 PM
1SlowHoe's Avatar
OUT OF CURIOSITY I DECIDED TO TEST THE #2 CYLINDER AGAIN WITH THE TB OPEN. WHAT A DIFFERENCE A LITTLE AIRFLOW MAKES! LOL I'm gonna go out on a limb here and say all cylinders would be near 175 if I had opened the TB...
Old Dec 30, 2010 | 07:25 PM
hog's Avatar
hog
the proper way to do the test is to have the throttle wide open. 150 psi looked kinda low.
peace
Hog
Old Dec 30, 2010 | 08:18 PM
1SlowHoe's Avatar
peace
Hog
Ya, I think I just forgot Been awhile. I remember my 5.3 being at 180psi when I was checking it, that's why I was a little worried when I saw 150psi yesterday. Opening the TB and doing it again and getting 180psi makes me feel much better lol
Avalanche2002
Nov 30, 2015 07:31 AM
BlownHD
Oct 3, 2015 12:24 PM
Velocity1
Oct 2, 2015 08:01 AM
old motorhead
Sep 29, 2015 08:22 PM
