Compression ratio
Old Oct 22, 2007 | 01:05 PM
Default Compression ratio
how do i figure up the compression ratio on my motor. any help will be very aprecciated
Old Oct 22, 2007 | 01:11 PM
Quik's Avatar
5 year bitches!
i know with a 20cc head its 9.2.. so you should right around 10.1. thats awful low for a N/A stroker.
Old Oct 22, 2007 | 01:21 PM
it has a dual stage 150 shot on it for know but will eventually be turbo charged.
Old Oct 22, 2007 | 01:22 PM
how hard was it for you to swap to a six speed. and what type of horsepower do you think i might have on all motor.
Old Oct 22, 2007 | 01:28 PM
Quik's Avatar
5 year bitches!
then you might want to think of lowering hte compression some more for a boosted motor unless you dont plan on making large numbers or you want to live on race gas
Old Oct 22, 2007 | 01:31 PM
Quik's Avatar
5 year bitches!
i think the compression is hurting you. you run the ms3 its a good cam. your combo is nice but since hte compression is roughly 1.5 pts lower then it needs to be you are leaving a good bit of power on the table. you might be 450 right now. if compression was higher then you would probably be at 500 or higher. its hard to honestly guess. best is dyno
6speed isnt hard to do but when behind a stroker it will eatup a stock t56!!! its a costly swap when dealing with a big motor
Old Oct 22, 2007 | 01:32 PM
what is your compression ratio
Old Oct 22, 2007 | 01:33 PM
Quik's Avatar
5 year bitches!
it was 11.1 for my NA motor. for my new setup i plan to be around 9.1
what is the stock deck height for these 6.0 motors
Old Oct 22, 2007 | 01:36 PM
Quik's Avatar
5 year bitches!
**** i dont remember
