Comp xr275hr
Old Nov 30, 2008 | 07:57 PM
  #51
BlackGMC's Avatar
Resident Retard
I just finished installing this cam today in my 4.8... My idles at 700-750ish... The low end on with this cam is better than 220/220 cam I took out of it... It really pulls up top too...
Old Jan 21, 2009 | 11:11 AM
  #52
What is the agreed pushrod length for this cam 7.4 length like stock or shorter. My heads are milled .045 with stock gaskets so I though I needed a 7.355 rod for the cam but you guys are saying you need a shorted one? Is the case circle different than a factory cam?
Old Jan 21, 2009 | 08:42 PM
  #53
05GTO6SPEED's Avatar
i have factory heads and i used 7.4
Old Jan 26, 2009 | 10:43 PM
  #54
ricoc's Avatar
.070" shorter required for mine, but CompCams will tell you to measure after install
Old Feb 14, 2011 | 02:11 PM
  #55
1quikzz's Avatar
I know this is thread is over 2 years old, but i was wondering about the pushrod selection for this cam. I'm installing it in my 6.0 with milled .010 heads. what length pushrods should I be getting?
Old Feb 16, 2011 | 03:11 PM
  #56
ricoc's Avatar
It really depends on how your valves sit in the heads. My heads had lots of hard miles on them so I needed shorter than normal rods to get proper lash. (or lack there of)
I cut one of my factory rods and built my own measuring tool. I recommend you measure instead of guessing or blindly putting parts in a motor because someone else got lucky with their build. There are lots of reports of people who want to know why theie motor "ticks" after a cam install.
Old Feb 19, 2011 | 09:52 PM
  #57
1quikzz's Avatar
I don't plan on "blindly" putting parts in my motor. What I'm having an issue with is inconsistent information. According to SI, GM spec for lifter pre-load is .85 -.100". This is for use on a factory cam with a base circle of 1.550"
The XR275HR has a smaller base circle of 1.485" or -.065 shorter than stock.
I cannot seem to find exactly what length the factory push rods are, but are supposed to be 7.385.
So if this is the case and my math is right.....
7.385 + .065 -.010. = 7.44?
Does this sound right or am I way off base?
Old Feb 21, 2011 | 01:34 PM
  #58
05gmcsierra's Avatar
to what i was told is that ur right ur base circle is .065 smaller but ur only suppose to take half of that and add it to ur pushrods because the radius of the base circle only goes down by half. get me? so with that said its only .0325 smaller and when u add that to 7.385 u get 7.4175.... ur heads are milled .01 then ur back at 7.4075... in other words u will be fine with hardened 7.4s.. thats just how i would figure the math out.. but u need a pushrod length checker.
Old Mar 6, 2011 | 10:56 PM
  #59
1quikzz's Avatar
That makes sense, Thanks
hodge9386
Oct 25, 2015 01:26 PM
Wolftrk99
Oct 2, 2015 08:17 AM
Velocity1
Oct 2, 2015 08:01 AM
jtphelps289
Sep 30, 2015 09:26 PM
