Was the comp 212/218 high or low lift?
Old Jul 3, 2004 | 10:50 PM
Question Was the comp 212/218 high or low lift?
I just read a previous thread from May 2003, trying to find results on the comp 212/218 cam in a 5.3. First I talked to someone that works at Thunder Racing, and he suggested the high lift that is installed in his 2001 4wd truck with a gain of 40rwhp with the 114lobe. However, the previous thread that I just looked at was installed in a 2000 5.3. It seems to be the low lift, because their was nothing mentioned about it being a high lift. In the thread that I read the results were 43rwhp gain over stock. Should the high lift make a little more power with low lift? I would rather go with the low lift if it going to make the same power. Is this the same story, maybe gator's99ta could help out on this one?
Old Jul 3, 2004 | 11:19 PM
one03sierra's Avatar
Formerly one92rs
Talking
they make a high and low lift 212/218 cam.
212-218-522-529-114
212-218-558-563-114
Old Jul 4, 2004 | 12:47 AM
Mr. Sandog's Avatar
From what I know, if you plan on keeping the stock heads, the high lift version will likely yield little gain over the low lift version. The low lift would be easier on springs. But I reserve the right to be wrong on this...
Old Jul 4, 2004 | 12:53 AM
99Silver6.0's Avatar
I heard the same thing. Thus why I didnt get the high lift 212/218.
Old Jul 4, 2004 | 08:53 AM
They do make a high lift version of the came, but it has to be custom made at the comp cams facility. They do make the 265 high lift but with a 115 lobe seperation. However you can order it with a 114 lobe seperation
Old Jul 4, 2004 | 10:29 AM
Sport Side's Avatar
Comps 212/218 high lift will yield better results than the low lift version of it
Old Jul 4, 2004 | 11:30 AM
I understand that the LS1 is a different motor than the 5.3, but in two recent articles in mags. the 265 cam only made 29 flywheel horses. If I decided to use the 265 low lift can I expect 40rwhp gain out of the 5.3? That is what I want to achieve and I dont want to buy a cam that is only going to give me little horses, but I still drive it on a daily basis. Can 40rwhp be coaxed out of the 5.3 with the low lift 265 because i plan on keeping the stock heads.
Old Jul 4, 2004 | 11:56 AM
Mr. Sandog's Avatar
You seem very concerned with measurement....which isn't a bad thing, but my experience with asking for it from other people here is that not too many people do before/after dynos with their stuff. For example, no one that I knew of did strict before/after dynos with a Radix install. I did. Maybe you will have to be the person to do it.
FYI, I've heard that on an otherwise stock 5.3L, the low-lift gets ~30HP.
Old Jul 4, 2004 | 09:52 PM
marc_w's Avatar
Yeah, the standard "low lift" cam is a 212/218 @.050", 265/271 advertised, .522/.529 lift on a 114LSA.
The "high lift" is a 212/218 .558/.563 @ .050", 265/271 advertised, on a 115LSA.
The main differences between the two are the extra ~.030" lift, and the 114 vs 115 LSA. I think the LSA makes the biggest difference between the two cams.
If you notice the lobes have the same @ .050" and advertised duration, so the lobes are very similar.
I saw the post (I believe I did) about the 5.3 making an extra 40 horse with the 212/218 high-lift. If you notice, the truck also got a ASP pulley installed at the same time, which is good for about 10-15hp from what I hear.
The flip side to that, is that some people say the ASP pulley "doesn't dyno well", meaning the pulley is most noticeable when revving through the gears quickly - not doing a long dyno pull locked in 3rd.
I think 40hp would be doable with good headers, free flowing cat-back, tuning, and (at least?) a drop-in filter.
chevy6.0fan
Aug 20, 2015 07:10 PM
Dirtywhite
Aug 5, 2015 04:10 PM
LARRY01Z28
Aug 1, 2015 10:15 PM
Castro45
24
Jul 31, 2015 07:13 PM
projectnightcrawler
Jul 19, 2015 11:30 PM
