Cometic head gaskets
Old Aug 18, 2005 | 10:38 AM
white1's Avatar
Default Cometic head gaskets
Which gaskets do I need for my 5.3? Are the LS1/LS6 gaskets them? Also with milled heads .020 can I use the thinner gaskets? Thanks
Old Aug 18, 2005 | 10:58 AM
BigKID's Avatar
If I were you I would just use the stock graphite gaskets for your truck. You are not making enough power to warrant the coin for cometics plus I dont think they make a 3.622 bore ls typegasket. The 3.905 ls1/6 bore gasket is not right for your 5.3.
Old Aug 18, 2005 | 11:25 AM
Silver-Dollar's Avatar
You get away with 3.905 bore size if your heads are 3.905. I called AFR not to long ago about his. Look at new heads and wondered if I needed to cylinder bore to match heads.
Old Aug 18, 2005 | 12:24 PM
white1's Avatar
Thanks for the help.
Bigkid, I was wondering if it was worth it for me to use the Cometics. Thanks
Old Aug 18, 2005 | 02:39 PM
BigKID's Avatar
You can also get the graphite gaskets from NAPA. I hear they are exactly the same as the GM ones but half the price. I used GM gaskets only because I have a hookup at the dealership.
Old Aug 18, 2005 | 04:32 PM
TURBHOE's Avatar
whitch one are the thicker ones from gm anybody know?
Old Aug 18, 2005 | 04:52 PM
BigKID's Avatar
The compressed thickness of the GM graphite gasket is .054" and the GM MLS gasket is .060".
Old Aug 18, 2005 | 08:36 PM
99Silver6.0's Avatar
Use the FelPro 1041's MLS gaskets if you want thinner. They are .041 compressed. Compressed thickness on a stock 6.0 gasket is .052.
I think Cometic can make what you need. But it is not cheap.
Old Aug 19, 2005 | 01:48 AM
Grey Silver's Avatar
11 Second Club
Cometic makes gaskets for the 5.3, I've got a set on my truck. I think I gave 150 for them but they're reusable.
Old Aug 19, 2005 | 01:23 PM
TURBHOE's Avatar
i just want a good gasket that can hold 7-10 pounds of boost on a ls1 that is a little thicker to get the compression down some.
thunder550
Oct 8, 2015 04:53 PM
slowlsx
Aug 13, 2015 08:28 PM
slowlsx
Aug 10, 2015 05:33 PM
BIGD4504
Jul 28, 2015 11:46 AM
