Cleaning engine
Old May 23, 2006 | 08:10 PM
CrunkGM99's Avatar
Default Cleaning engine
Whats the best way to clean up the engine compartment? On my old body style, I just sprayed a couple of cans of engine brite on the 5.7, then hosed it off with a light stream of water. I'm kind of weary on using this method on my new body style though, due to the increased amount of electronics involved. What do you guys think?
Later, Crunk.
Old May 23, 2006 | 08:23 PM
SnakeOiler's Avatar
I spray my with water then wipe it down. I do my Camaro and Impala the same way.
Old May 23, 2006 | 08:59 PM
Quik's Avatar
5 year bitches!
wet motor, GP it then rise then let it run and dry off
Old May 23, 2006 | 09:36 PM
TXsilverado's Avatar
cover alt with plastic bag...drench engine in degreaser or carb cleaner(avoid battery terminals)...let sit for 5 minutes then hose off with low pressure. repeat if necessary. dry with compressed air.
cover engine and fire wall with mcguires foaming tire shine(avoid belts)..let stand for 5 minutes and wipe down with cotton cloth.
Old May 24, 2006 | 08:03 AM
CrunkGM99's Avatar
Ok, so its cool to get the motor wet, but what's GP?
Old May 24, 2006 | 02:47 PM
95ImpSS's Avatar
formerly 1BADC10 (12/14/2011)
TXsilverado... that looks just like the underhood of my Yukon.
Old May 24, 2006 | 09:27 PM
BADMOFO's Avatar
Cuz I AM a BADMOFO
Believe it or not, I use No-Touch tire **** on all of my black stuff ie. battery, engine cover, brake booster, fuse box, shroud, etc. It looks like new. I rub it around with a rag on the hard to reach spots. Of course if it's real dirty I use soap and water first, but be careful around the coils and top of motor.
Old May 24, 2006 | 09:39 PM
Quik's Avatar
5 year bitches!
GP
General
Purpose
its a degreasor like purple power and etc
Old May 24, 2006 | 10:11 PM
So if I wanted to just spray out all the pollen under my hood can I just take a hose to it with no problems? Or will I HAVE to cover something to keep it from malfunctioning?
Old May 24, 2006 | 10:15 PM
you dont HAVE to cover the alternator but its not a bad idea. dont use simple green on the motor. it corrodes the alt and brackets.
thunder550
Oct 8, 2015 04:53 PM
tweeder
Sep 18, 2015 11:02 PM
wheeliE-maxx
Jul 19, 2015 05:37 PM
Ferocity02
Jul 17, 2015 07:05 PM
Suburban2500
Jul 14, 2015 02:10 AM
