!Check your stock Manifold/Header Bolts!!!
Old Apr 3, 2007 | 11:12 PM
  #21
cyamaha2007's Avatar
ive welded nuts to the studs before its a simple process
1 remove manifold
2 spray stud with pb blaster
3 spray stud with more pb blaster
4 with a heat gun or propane torch evenly heat up the area around the broken stud
5 have a buddy hold a nut (that has a smaller inner diameter than the stud) over the stud flush with the head and fill that inside of the nut with weld
6 let the weld nut and stud cool
7 when the weld is COLD evenly heat the area about 1in from the stud
8 while the head is hot put a wrench on the nut and try to back it out.
good luck hope this helps this method has done the trick for me twice
Old Apr 11, 2007 | 01:23 PM
  #22
shupe's Avatar
Default bolt removed
Got it out. Took to buddys shop, he welded a nut to the broken stud and just backed it on out. Made it look like easy.
5.3Okasai
Mar 9, 2022 01:07 PM
thunder550
Oct 8, 2015 04:53 PM
08nali
Jul 23, 2015 11:39 PM
4B11T
Jul 13, 2015 03:48 PM
GreyChevy
Jul 7, 2015 08:57 PM
