!Check your stock Manifold/Header Bolts!!!
Old Mar 23, 2007 | 12:46 PM
WhiteChevy3's Avatar
Default !Check your stock Manifold/Header Bolts!!!
just recently i have had an exhaust leak, after looking it appered that the drivers side rear manifold bolt was missing, but after finding one to fix the prolblem, i discovered that it had broke and the head had fell out.
i thought well mabey ill check the one behind it, i had just put the 10mm wrench on it and barely turned it to tighten and it fell out!! hanging on by a thread, another one broke
a few questions, whats the easiest way to extract the stud out? i am sure it is flush with the head. are these aluminum heads on my 99? mine appear to be.
after this i will be replacing all of them with APR!!, hopefully theres not any more broke!
Old Mar 23, 2007 | 01:00 PM
truckmann's Avatar
You can try some easy outs or a reverse rotation drill bit and lots of PB Blaster.
Old Mar 23, 2007 | 01:26 PM
syclone0569's Avatar
i have a broken one on the drivers front most bolt.......puzzling??
Old Mar 23, 2007 | 01:37 PM
Nick™'s Avatar
I'll just use ARP's
"left-hand" drill bit/ easy out would be your best bet.
Old Mar 23, 2007 | 07:34 PM
COLDZ71's Avatar
Thats really interesting, mine broke off the driver's front also. I wasnt about to use an "easy" out. Never had any luck with them, even though I have seen others use them with success. What I did to get it out was weld a nut to the end of the broken bolt. The bolt broke flush with the head so I just held the nut in place while my friend welded them up. Put a wrench on it and it came right out.
Old Mar 23, 2007 | 07:39 PM
greencountry05's Avatar
Mine were good and tight....knock on wood.
Old Mar 23, 2007 | 08:50 PM
bud8fan's Avatar
that back one is a pain in the ***....pull your head off and extract them....
Old Mar 23, 2007 | 10:02 PM
For some reason we have had a rash of these truck through the shop with the same problem lately. We just pull the heads and use a variatable cornicopia of methods depending on how it brok and what's left of the bolt.
Old Mar 23, 2007 | 11:53 PM
blake2kz71's Avatar
if you have any machining skills or have drilled out broke bolts at all do it yourself, if not save some time and take it to a machine shop. i wouldnt think twice about pulling the head and taking it to a shop if i didnt have any experience with it. this is definately not an area to take a shortcut.
Old Mar 23, 2007 | 11:57 PM
cyazo6's Avatar
Welding a nut on to the broken stud and puting a wrench on it is how I do it to.
