check engine light
Old May 12, 2004 | 09:25 PM
The_Mexican's Avatar
Default check engine light
The check engine light went on for the third time, a friend that works on a gm dealer told me that it is because of the cam swap and it's weird idle, and that I'll have to live with it because no matter how many times he erase the code it will come back on.
It doesn't make sense to me since Nelson fixed idle with his tune.
So, is there a way to fix this with LS1edit?
Other options?
Thanks.
Old May 12, 2004 | 09:54 PM
"If" it is the random misfire code, yes. Allen can fix that for you with edit.
Old May 13, 2004 | 01:41 AM
Flyer's Avatar
I don't think your friend is right. The way Allen fixed mine (the misfire tables) it wouldn't have thrown a code unless it had a dead miss, like a plug wire was pulled off or a plug broke or something severe like that. Did he get the code number and definition? Get that and it will be more useful.
Was it blinking or just solid on?
Old May 13, 2004 | 03:31 PM
Thanks guys, I don't remember the code number, but I'll sure get it.
The light was steady, no flashing, but I'll check all the plug wires and plugs.
Thanks.
Old May 13, 2004 | 05:19 PM
Flyer's Avatar
No flashing ... it more than likely wasn't a misfire code then.
Old May 13, 2004 | 07:19 PM
BigTex's Avatar
It wont be flashing if its the random misfire at idle. It will flash if its a true misfire at higher rpms.
Old May 13, 2004 | 08:02 PM
FILE's Avatar
It was probably the PO 300 code. I have that code that I need to get taken care of.
tweeder
Sep 18, 2015 11:02 PM
GMCtrk
38
Aug 9, 2015 08:50 PM
Ketis
Jul 23, 2015 12:37 PM
bsgiffor
Jul 19, 2015 11:14 AM
hackrst
Jul 11, 2015 11:17 AM
