Catch Can Filling Way Too Fast
Old May 19, 2017 | 12:31 PM
  #21
Gadgetized's Avatar
Just make sure you have the pressure escaping through the catch can.
Old May 19, 2017 | 06:21 PM
  #22
bobfig's Avatar
Originally Posted by Gadgetized
I would personally just run both to the catch can. I don't like to run oil through an engine. When I get time to set mine up right, it will be off the front of each valve cover.
the passinger side isnt pulling oil. that one pulls air into the crank case where the driver side sicks it out...
Originally Posted by JonToski187
Should I plug my passenger side though?
i would not cap it
Old May 22, 2017 | 11:36 AM
  #23
RA62025's Avatar
Banned
i would not cap it
Alright thank you. I think my problem might be that the catch can added some more restriction and it causes it to "suck" up oil from the driver side valve cover. I took out some extra filtering material I added in the catch can but it is still filling up. I let my truck idle as well and it's filling up about the same rate as driving. I think I need wider tubes. But if I go any wider I won't get a good connection on the intake or valve cover nipple. Should I put in a breather or something some where?
Old May 24, 2017 | 01:00 PM
  #24
bobfig's Avatar
Check to see if you have the revised valve cover
Old May 24, 2017 | 01:06 PM
  #25
RA62025's Avatar
Banned
Yes I have the one that is fix mounted to my valve cover. Because it is a 07 classic
Old May 24, 2017 | 02:48 PM
  #26
bobfig's Avatar
you sure you know what i am saying?!?
SilveradoSierra.com ? Valve cover replacement : Vortec 5300 5.3L V8
Old May 24, 2017 | 03:04 PM
  #27
RA62025's Avatar
Banned
I see what you are saying now. I have an open hole one. Maybe I will try and block it somehow
Old Jun 13, 2017 | 10:18 AM
  #28
RA62025's Avatar
Banned
So a lot of trouble shooting and "easy" fixes went down while I haven't posted. I ended up getting frustrated and ended up buying a valve cover with the revised hole on the inside that was suggested for $150!!! drove home and what would normally fill my can up there was only a few drops in it now. I'll call it fixed and thanks for all the help from everyone.
