Cat?
Old Feb 3, 2009 | 07:56 PM
1andOnly's Avatar
Default Cat?
Alright I have the infamous po300 code and I read most of the threads and I cleaned the maf,throttle body, change plugs and wires and drop in a can of seafoam....The next step is the injectors....and I read on here talking about the cats going bad is there a way to tell if the cats are bad other than smell Its just killing me everytime I save up the money for my heads something else comes up and if I have to replace the cats Im buying a complete exhaust
Old Feb 3, 2009 | 08:08 PM
budhayes3's Avatar
PT's Slowest Truck
Usually when the cats are bad enough to cause a misfire, the engine won't rev above 4k and will start to break up. You can check for a restriction in the exhaust with a vacuum gauge hooked up to a port on the intake. At idle the engine should have over 17 mmhg (that number will vary depending on if the cam is stock or not, larger cams with more overlap will have a lower number, while the stock cam will idle around 21 in park or neutral). When you rev the engine it should drop to 0, then quickly jump up to over 21 when you snap the throttle shut. If the gauge sticks or slowly rises after snapping the throttle shut, there is a restriction in the exhaust.
Old Feb 3, 2009 | 08:24 PM
1andOnly's Avatar
Ill see what I can do ,First Ill get some 8.1L injectors...
Old Feb 3, 2009 | 08:51 PM
budhayes3's Avatar
PT's Slowest Truck
I just noticed the cam in your sig, sometimes larger cams can cause false misfire codes, although I'm assuming that Wheatley tuned for that and softened up the misfire monitors...
Old Feb 3, 2009 | 09:33 PM
1andOnly's Avatar
Well everything was fine until this winter...
Old Feb 3, 2009 | 09:36 PM
1andOnly's Avatar
Ill talk to my brother and ask him he has the same cam I drove his Avy and never seen a code or I might give Wheatley a call....
Old Feb 3, 2009 | 09:50 PM
budhayes3's Avatar
PT's Slowest Truck
Yea, probably not cam/tuning related then...
Old Feb 3, 2009 | 09:51 PM
budhayes3's Avatar
PT's Slowest Truck
Has the problem happened with more than one tank of gas? (trying to rule out bad gas...)
Old Feb 4, 2009 | 05:47 AM
1andOnly's Avatar
Yes I thought that was it to I was using Phillips66 I went to Shell and its tuned for 93 Oct...
madmann26
Apr 29, 2020 09:17 AM
FlowmasterMufflers
Nov 24, 2015 01:00 PM
BlownHD
Oct 3, 2015 12:24 PM
Wolftrk99
Oct 2, 2015 08:17 AM
02AWDAWSDenali
Oct 1, 2015 05:08 PM
