can a lifter turn?
Old Oct 11, 2005 | 03:10 PM
  #21
Fogle07's Avatar
no thats not correct. the first cam swap almost a year ago had a lifter fall. i made tools this time to hold them up. all the lifters are there. just making some crazy sound and im trying to figure out what it is. i knew i should have left that pos stock
Old Oct 11, 2005 | 03:35 PM
  #22
Fogle07's Avatar
also how long do you guys think the stock springs will last with the tr227 in it. i had the 212/218 comp in there with the stock springs for prob. 12-15k miles. now i got the stock cam in there but im going to be pulling it back out to see if its messed up and if it is im thinking of throwing the 227 in there.
Old Oct 11, 2005 | 04:01 PM
  #23
02Reaper's Avatar
Originally Posted by treyZ28
just unbolt the intake manifold and take that plate off. Valve covers come off, but thats it.
are your pushrods the correct length? rockers torqued correctly
This will not work for viewing our lifters. If they have to be checked out or replaced, the heads have to come off. Sucks, but thats how it is.
Old Oct 11, 2005 | 04:03 PM
  #24
Fogle07's Avatar
any other suggestions to find out what it is?
Old Oct 11, 2005 | 05:24 PM
  #25
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
The stock springs will be alright with that cam but oyu shouldnt run it hard or you will float the valves. I would give you mine for the paint work stuff but they are already spoken for.
Old Oct 11, 2005 | 05:46 PM
  #26
Fogle07's Avatar
you think it will be ok turning 6000?
Old Oct 11, 2005 | 06:07 PM
  #27
1slow01Z71's Avatar
I dont know man that is alot higher lift cam than stock and the lobes on that cam are alot more aggressive you will be able to tell when the valves are floating but you better back out it immediately. I would just put springs on there if you are going to go to the trouble of putting cam in there or I can send you my 6L cam if that one is messed up Im not going to use it.
Old Oct 11, 2005 | 06:15 PM
  #28
Fogle07's Avatar
well i got the rockers and pushrods off and they look fine. im about to pull the cam. ill be right back
Old Oct 11, 2005 | 06:20 PM
  #29
Fogle07's Avatar
ok heres one for ya. the cam bolts are longer than the cam retainer bolts. could this be my prob. that i got them mixed up? they dont have any scrape marks on them though. im pulling the cam anyways
Old Oct 11, 2005 | 06:27 PM
  #30
1slow01Z71's Avatar
Was the cam retainer nice and snug to the block and was the timing chain gear nice and snug to the cam?
