Can a fuel filter hold back alot of performance?
Old Jul 16, 2003 | 09:22 PM
Default Re: Can a fuel filter hold back alot of performance?
what kind of performance filters are you guys using and where do you get them and part number too if possible. thanx guys.
Old Jul 16, 2003 | 09:23 PM
BlownChevy's Avatar
blownerator
25 Year Member
I used the OEM filter I got from the stealer.........
Old Jul 16, 2003 | 11:50 PM
CashDudeHomie's Avatar
It helps if you unplug the fuel pump relay and run the truck until it dies. Then remove the gas cap and unscrew the fuel pressure test port on the intake and stick something in to get any more pressure out. Then it won't spray all over. I always had a hard time slipping the filter out of the bracket. I can remove both bolts but the bracket is still secured to the brake lines and it is a bitch to wiggle it out. Any special techniques?
Old Jul 17, 2003 | 01:52 AM
GoldenVelvet's Avatar
I need to get my oil changed. Im thinking maybe I sould change my fuel filter also.
I normally run injecter cleaner every 10K but at 2xK on the ODM i think its due
ARC
57
Feb 21, 2022 10:54 AM
lxcoupe
Jul 21, 2015 02:12 AM
cbhedrick
Jul 20, 2015 10:12 PM
76k10chase
Jul 17, 2015 01:48 PM
jrplz
Jul 9, 2015 12:07 AM
