Can a fuel filter hold back alot of performance?
Old Jul 16, 2003 | 10:58 AM
14 Second Truck Club
Default Can a fuel filter hold back alot of performance?
I've got about 47,000 miles on my truck and haven't replaced the fuel filter, rear end fluid, or transmission fluid. The guy where I get my oil changed said Iwas supposed to get my fuel filter changed at 2x,000 miles. Is this hurting my performance?
I plan on getting it changed next week along with my oil, just wondering?
Old Jul 16, 2003 | 11:03 AM
Neil 6.0's Avatar
From: as far away from Koonerville as humanly possible
Default Re: Can a fuel filter hold back alot of performance?
No! Don't change it! Ever!
Old Jul 16, 2003 | 11:32 AM
Hit Man X's Avatar
WHen I picked up my "GM Certified" truck it still had the ORIGINAL fuel filter on it with 37K mi. Needless to say that was the first thing I changed and made a difference in MPG and performance.
Besides it takes ~30min from gathering tools to putting everything back to do it.
Old Jul 16, 2003 | 11:37 AM
BigKID's Avatar
LMAO @ Neil. Definately change the fuel filter. I change mine every 20K. Nine bucks and a little spilt gas is worth the piece of mind.
Old Jul 16, 2003 | 11:55 AM
Thanks Guys! Now I wonder if it will help my gas mileage and performance any.
Old Jul 16, 2003 | 01:39 PM
Hit Man X's Avatar
Oh yeah it should for sure. Just get some unbias other source to drive it before and after.
Old Jul 16, 2003 | 05:02 PM
isnt the fuel filter in the tank?
how hard is it to do?
Old Jul 16, 2003 | 05:07 PM
XLR8NSS's Avatar
Adkoonerstrator
The fuel filter is on the frame rail on the drivers side and all it requires is a line wrench to undue the fittings. I don't know what size but, I think it's pretty big. You really don't even need the line wrench but, I have destroyed those fittings before with regular wrenches.
Might need a screw driver also. I've never changed mine but, have been thinking about it.
Old Jul 16, 2003 | 06:34 PM
I went with a Canton high capasity fuel filter it may be overkill but with a supercharger or a shot of nitrous you can't be to carefull.The filter is a little pricey but it has 1/2 the restriction and uses replaciable elements.
Old Jul 16, 2003 | 08:23 PM
Neil 6.0's Avatar
The hardest part is keeping the pressurized gas from squirting into your face after you loosen the lines at the filter. So be sure to use an old shop rag to block the money shot. Don't be surprised if about 5 gallons of gas tries to drain down the framerail and then drip onto your crotch.
