Can a crew cab 5.3 be fast? Apparently not
Old Jun 18, 2005 | 04:52 PM
stssilverado's Avatar
Default Can a crew cab 5.3 be fast? Apparently not
Has anyone seen a crew cab 5.3 that is remarkably fast? I've spent near $6k on mine and only ran 15.7 last night. 8psi sts, 2800 stall, fuel pump, injectors. Left the line @ 4-5 psi boost. Is the truck just too heavy?
Needless to say, it WILL go fast eventually. Just pissed off right now.
Old Jun 18, 2005 | 05:04 PM
check sierracrew out. hes is running 14.2 na. and thats with wheel spin. something must be wrong with yours if you have a sc and you're running that slow. i would check into your tune.
Old Jun 18, 2005 | 05:13 PM
02sierraz71_5.3's Avatar
I have an ext cab z71 it should weigh close to yours, Ive run consistent 9.00 in the 1/8 Im expecting better times with a cutout, new tune and weight reduction that should plant me in the 13's NA. Something is wrong with your setup, are you running 93 do you have alot of kr i agree with kbobo something is really not right and its probably in your tune. You should be in the high 13's at least
Old Jun 18, 2005 | 05:18 PM
FILE's Avatar
Something is serously wrong with your set up. I agree, you should in the high 13's to low 14's.
Old Jun 18, 2005 | 05:20 PM
Gran Patron's Avatar
Somethings absolutely wrong there! Gots to be with the tune! Recheck that.
Yeah sierracrew has a cam and a cuople of other performance mods and is running low 14's.
Old Jun 18, 2005 | 05:21 PM
ap2002's Avatar
I would say there is something wrong with your set up..... you should be in the 13's or low 14's...
Old Jun 18, 2005 | 05:25 PM
quicksilverado's Avatar
Blownchevy just ran 13.7 in his s/c 5.3 crewcab. You tuning is probably the problem.
Old Jun 18, 2005 | 05:30 PM
Crash Dummy's Avatar
Former Moderator :(
Must be the tuning !
Old Jun 18, 2005 | 05:35 PM
TurboBerserker's Avatar
I AM A MOTHERF*CKER
Old Jun 18, 2005 | 06:35 PM
BlownChevy's Avatar
blownerator
25 Year Member
beat me too it.
