Can a crew cab 5.3 be fast? Apparently not
Has anyone seen a crew cab 5.3 that is remarkably fast? I've spent near $6k on mine and only ran 15.7 last night. 8psi sts, 2800 stall, fuel pump, injectors. Left the line @ 4-5 psi boost. Is the truck just too heavy?
Needless to say, it WILL go fast eventually. Just pissed off right now. |
check sierracrew out. hes is running 14.2 na. and thats with wheel spin. something must be wrong with yours if you have a sc and you're running that slow. i would check into your tune.
Somethings absolutely wrong there! Gots to be with the tune! Recheck that.
Yeah sierracrew has a cam and a cuople of other performance mods and is running low 14's. |
I would say there is something wrong with your set up..... you should be in the 13's or low 14's...
Blownchevy just ran 13.7 in his s/c 5.3 crewcab. You tuning is probably the problem.
Must be the tuning !
beat me too it. :usa: |
