cams specs?
Old Dec 30, 2002 | 10:58 AM
RED2K's Avatar
Default cams specs?
Doesn anyone know what the specs are for a stock 98 ls1{z28] cam is and what mine are for my 2000 5.3. I sold the 2001 z06 cam because of people saying i would lose too much down low. I have this z28 cam sitting here doing nothing and thought since i dont have to change the springs, that i might throw it in. I know the probably isnt a bid difference but it is laying around.
Old Dec 30, 2002 | 01:29 PM
RED2K's Avatar
Default Re: cams specs?
ttt
Old Dec 30, 2002 | 01:35 PM
BigTex's Avatar
Do a search in the internal engine section. If no luck there, search it over at LS1. It will have more duration than your 00 cam, but probably not much more lift. I personally don't think it would be worth your time. You don't even need to change the springs to run it.
Old Jan 1, 2003 | 12:58 AM
JWRENCH's Avatar
Man, been there done that. <img border="0" alt="[bang head]" title="" src="graemlins/gr_banghead.gif" /> Don't even waste your time cause it'll suck. And it's a 201/212/500/500 with lobe centerlines at 122/117 and a crappy LSA of 119.5°.
Honestly, mine wouldn't even power brake at all with it in there and I only got a slightly noticble top end gain. <img border="0" title="" alt="[Frown]" src="gr_sad.gif" />
Old Jan 1, 2003 | 10:04 PM
RED2K's Avatar
so you lost every bit of your bottom end power?
Old Jan 1, 2003 | 10:19 PM
JWRENCH's Avatar
Yes sir I did. I honestly held the gas pedal to the floor for several seconds while holding on the brakes and it wouldn't even spin. <img border="0" title="" alt="[Mad]" src="gr_images/icons/mad.gif" /> Normally at half throttle it would set there and roast the tires off. I had to turn around and put the stocker back in to get the power back. Big waste of time for sure.
I think if it had the 112-114 LSA like the aftermarket cams it would've helped but with that rediculous 119.5, it pushed all the power up to about 5500 rpm's and up. Below that it was just a dog. <img border="0" title="" alt="[Frown]" src="gr_sad.gif" />
Old Jan 1, 2003 | 10:55 PM
RED2K's Avatar
Thanks man <img border="0" title="" alt="[Eek!]" src="gr_eek2.gif" />
lawhitediamante
Aug 12, 2015 12:14 PM
OLD BULL
Aug 1, 2015 05:00 PM
steves86ta
Jul 28, 2015 10:21 AM
GRRR65GTO
Jul 10, 2015 08:27 PM
NuckenFuts
Jul 9, 2015 08:45 AM
