Camming the 6.0.
Old Dec 30, 2010 | 08:26 PM
youngbuck's Avatar
Default Camming the 6.0.
What cam for the 6.0? Have a 4k stalled 4l80 with a shift kit an 3.42s, not changing gears truck is in sig. Was looking at the tsp 228r on a 110 or 111 want it sounding nasty at idle. What do y'all think? Good match? Better cam to go with? I also have a tbss intake to go with this in the near future. Thanks.
Old Dec 30, 2010 | 08:42 PM
Rhino79's Avatar
9 Second Club
With your converter I would shoot for mid 230's on duration, maybe even a little more than that, depending on your goals and heads. Stock heads Id stick to 230's on duration at .050.
Old Dec 31, 2010 | 05:02 PM
youngbuck's Avatar
Ya heads are stock 317s.
Old Dec 31, 2010 | 05:04 PM
youngbuck's Avatar
An it is a dd so don't wanna get to crazy with the cam. Thoughts?
Old Dec 31, 2010 | 07:28 PM
10 Second Truck Club
i would do a 228-232 or 230-236 something like that at 110 or 108lsa
Old Jan 1, 2011 | 10:34 AM
06Sierra2's Avatar
i dont understand a 4k stall and a nasty idle cam on stock heads. i mean my heads are still stock but im running a 5.3 with a smaller cam and only a 3200 tc. ported 243s are in the future. are u planning on upgrading the heads later? with that much stall you can run a pretty big cam. but with stock heads id say low 230s maybe like the tsp v2
Old Jan 1, 2011 | 10:36 AM
06Sierra2's Avatar
tsp228r would also be a great choice tho imo if you decide your not gonna switch heads
Old Jan 1, 2011 | 11:59 AM
Rhino79's Avatar
9 Second Club
Well with his 317s they flow much better than the 5.3 heads. A stock engine peaks torque over 4000 rpms, I think you are fine on the converter, eps has some good looking cams for stock intake and cathedral heads.
Old Jan 1, 2011 | 12:52 PM
youngbuck's Avatar
Yea my peak torque is at 4400, tho im shifting at 5850 cuz thts when it stops pulling, an also the reason for the tbss intake I'm going to put on.
Old Jan 2, 2011 | 01:35 PM
youngbuck's Avatar
so would the 228 be the best overall? Or should I step it up to the v2 ?
